[Qgis-developer] Unclear errors in PostGIS layer
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Jun 28 05:31:14 PDT 2013
Hi Paolo,
The following SQL statement worked for me to clean invalid geometries
from a table, which I was not able to work with in postgis (independent
of QGIS)
select * from multipolygons where not st_isvalid(wkb_geometry)
After inspecting the invalid geometries, you can replace "select *"
with "delete" to get rid of the rows in question.
Hope that helps,
Matthias
On Fre 28 Jun 2013 14:27:33 CEST, Paolo Cavallini wrote:
> ********* *BEGIN ENCRYPTED or SIGNED PART* *********
> Hi all.
> I'm getting errors while loading a PostGIS layer:
> Impossibile recuperare il cursore qgisf3_0
> Errore database: ERROR: geometry requires more points
> Interrogazione: CLOSE qgisf3_0 ha restituito 7 [ERROR: current
> transaction is aborted, commands ignored until end of transaction block
> 1 degli stati del cursore perso.
> SQL: CLOSE qgisf3_0
> Result: 7 (ERROR: current transaction is aborted, commands ignored until
> When checked, however, the layer has no invalid geometries (Topology checker plugin
> and Vector>Geometry>Check geometry).
> Any hint on ho to debug this?
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> ********** *END ENCRYPTED or SIGNED PART* **********
> Qgis-developer mailing list
