[Qgis-developer] Tool for creating unit tests for SEXTANTE.
Paolo Cavallini
cavallini at faunalia.it
Thu Mar 7 10:55:53 PST 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 07/03/2013 09:53, Victor Olaya ha scritto:
> Hi all,
> I have been thinking about how to ease the process of creating unit
> tests for SEXTANTE algorithms. Ideally, there should be (at least)
> a test for each algorithm. I do not fancy the idea of automating
> that
Hi Victor,
thanks for that. I think the problem can be split in two:
* checking that a module works
* checking that it works well.
The first one would simply mean that a module would produce an output
(of the type expected); I think this check should be run automatically
at every commit into the sextante code, to be sure nothing breaks
badly. I think this should be very easy to implement, and could be
done soon. Most errors will be spotted this way. Many less used
modules can break without nobody noticing it.
Your suggestion address the second issue, and is obviously better, but
it will take longer to implement.
So I would suggest to implement the first one soon, doing the second
for a GSoC or other.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlE44rgACgkQ/NedwLUzIr5YAACeMocd4JkmO+NDQ9QbwM+PQrB8
V/0AoJVPbIcDJbCVyEbjpAGuzRGV1jfj
=JrQh
-----END PGP SIGNATURE-----
