[Qgis-developer] some questions about GRASS features in QGIS
Paolo Cavallini
cavallini at faunalia.it
Sat Mar 9 11:09:18 PST 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 09/03/2013 17:40, William Kyngesburye ha scritto:
> - Can the plugin access/start the GRASS GUI? I mean just the full
> GUI started with g.gui. Is there really any benefit to doing this
> in QGIS?
IMHO not
> - Can the plugin use the command mini-GUI things (whatever they're
> called), that start when you run a GRASS command without
> parameters? Seems redundant if it can, since the plugin has it's
> own GUI forms for filling in command parameters.
Not all the commands and options are included, so yes, it is useful,
even if unelegant.
> - Then there are a couple tools that only run in a small GUI
> interface, like NVIZ (in its multiple forms). How does the plugin
> handle these? Not at all, or let them run as is?
It lets run them.
> - can the plugin run arbitrary GRASS scripts or modules (ie user
> scripts and addon modules)?
it could, if the module developer writes also the necessary qgm
Thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlE7iN4ACgkQ/NedwLUzIr6pmwCeKp4ecoRJp7YOP395BcRM0YIi
rwMAnR+3awT5i154YMo5U5o+Ql9wnsFx
=+Jlf
-----END PGP SIGNATURE-----
