[Qgis-developer] Update to staged plugins
Larry Shaffer larrys at dakotacarto.com
Mon Mar 11 10:39:40 PDT 2013
On Mon, Feb 18, 2013 at 8:20 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi,
> I've committed an update to python/plugins/CMakeLists.txt [0] that changes
> how staged plugins are built (resources generated and copied to [build
> dir]/output/python/plugins). Staged plugins allow plugins to be available
> when QGIS is run from the build directory and was originally coded by
> Sandro Santilli.
> When staging all plugins, use the following make targets after a regular
> QGIS build:
> *  staged_plugins - stage plugins (usually after repo pull/build and
> project make)
> *  staged_plugins_pyc - stage and byte-compile all Python scripts
> *  clean_staged_plugins - removes the plugins directory and all contents
> When developing on a plugin, use the following make targets:
> *  staged_[plugin_dir_name] - stage specific plugin, regenerating any
> changed resources
> *  clean_staged_[plugin_dir_name] - removes the plugin directory and its
> contents
> CMake options WITH_STAGED_PLUGINS and WITH_PY_COMPILE are still valid and
> just run 'staged_plugins' or 'staged_plugins_pyc' respectively (if
> WITH_STAGED_PLUGINS=TRUE) at the end of a regular project build.
> In the newly available workflow for running QGIS from build directory,
> leaving WITH_STAGED_PLUGINS=FALSE (should be as default now?), all above
> targets are still generated, but not built as part of ALL target. This
> allows a developer to set up their IDE with custom build process steps like
> so:
> * make
> * make staged_plugins (optional)
> * make install (optional)
> with 'make staged_plugins' capable of being built anytime after project
> build, making those project builds as fast as possible, as done here with
> QtCreator project setup [1].
Sandro has updated the target names to be more in-line with Gnu target
naming conventions (using - instead of _) [0]. Everything else, as far as
the workflow, remains the same.
Example: 'make staged_plugins' is now 'make staged-plugins'
Regards,
Larry
[0]
https://github.com/qgis/Quantum-GIS/commit/aba568b96a96f98cd68a75aec92fbefd63b129f0
>  If you work on core Python plugins, please let me know how the new
> workflow for making staged plugins works for you.
>  [0]
> https://github.com/qgis/Quantum-GIS/commit/e33bd25c62d87b55fc121030638b1f178a9aec36
> [1] http://drive.dakotacarto.com/qgis/make_staged_plugins.png
> Regards,
> Larry
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130311/70afb5f5/attachment.html>
