[Qgis-developer] No rule to make target staged_plugins
Radim Blazek
radim.blazek at gmail.com
Tue Mar 12 03:45:52 PDT 2013
On Tue, Mar 12, 2013 at 11:09 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, Mar 12, 2013 at 10:34:28AM +0100, Radim Blazek wrote:
>> On Tue, Mar 12, 2013 at 10:18 AM, Sandro Santilli <strk at keybit.net> wrote:
>> > On Tue, Mar 12, 2013 at 10:05:59AM +0100, Radim Blazek wrote:
>> >> On Mon, Mar 11, 2013 at 6:46 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> >> > Hi Radim,
>> >> > Could you start an issue ticket for this, possibly including some specs,
>> >> > like which version of cmake, compiler, etc.? I can not discern what might be
>> >> > causing the problem for your setup, but working for everyone else (I'm
>> >> > assuming that), and would like to exchange some patches since I can't
>> >> > reproduce it here.
>> >> We have enough serious issues, is not sufficient to set
>> >> WITH_STAGED_PLUGINS=OFF by default?
>> > I think the default should be that output/bin/qgis works and can load
>> > all new core plugins, so developers can test and users can use multiple
>> > versions. That seems to currently mean "staged plugins".
>> > I can't find any issue filed on hub where [Subject contains "staged"]
>> > You mentioned that WITH_STAGED_PLUGINS=OFF works for you, right ?
>> > Does "make staged-plugins" work after that ?
>> Yes, as I already reported. It is
>> make staged-plugins-on-build
>> causing the problem:
>> *** No rule to make target `staged-plugins', needed by
>> `python/plugins/CMakeFiles/staged-plugins-on-build'. Stop.
> Do you have a `python/plugins/CMakeFiles/staged-plugins-on-build.dir'
> directory ?
Yes.
> What version of cmake are you running ?
2.8.2
Radim
