[Qgis-developer] Multicolumn legends in print composer
Mathieu Pellerin
nirvn.asia at gmail.com
Thu Mar 14 02:24:00 PDT 2013
What's described below is cool, would work out just fine : ) having this
alongside groups would work perfectly, probably even better than hack-ish
status of the past.
M
On Thu, Mar 14, 2013 at 4:05 PM, Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr> wrote:
> Hi, ****
> +1 with Radim. Such hacks do produce inconsistencies and bugs not
> compatible with collaborative coding. IMHO, we need clean coding in QGIS.
> A feature already asked I remember could solve both issues. Some of us
> asked that for layers having single symbol style, symbol in legend should
> be drawn on the same line as layer’s title (like in Arcgis or mapinfo).
> http://hub.qgis.org/issues/6960****
> Using groups will then help reaching Mathieu’s goal? ****
> Opinions?****
> I’m ready to put that in a contract if needed****
> Régis****
> *De :* Radim Blazek-2 [via OSGeo.org] [mailto:ml-node+[hidden email]<http://user/SendEmail.jtp?type=node&node=5040290&i=0>]
> *Envoyé :* jeudi 14 mars 2013 09:47
> *À :* HAUBOURG
> *Objet :* Re: Multicolumn legends in print composer****
> IMO, using empty layer title to achieve grouping of items from
> multiple layers into a single layer (group) is just a workaround. If
> it was working for some reason in previous versions (probably because
> there was no difference between layer and item spacing) it does not
> mean that we must add new and new hacks to the code to support it
> forever.
> I am not convinced that removing layer space if the layer title is
> empty (
> http://hub.qgis.org/projects/quantum-gis/repository/revisions/08c8857/diff/src/core/composer/qgscomposerlegend.cpp)
> is good. It is a hack to support your need but it introduces another
> bug and inconsistency because other user may require hidden layer
> titles (if empty) but still keeping layer spacing.
> A clean solution could be to add a new group "Road & Railways" with
> roads and railways layers inside and implement something like flatten
> sublayers check box for the group, which would put items of all
> sublayers directly into the group, ignoring layer titles.
> Radim
> On Wed, Mar 13, 2013 at 1:30 PM, Mathieu Pellerin <[hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=0>>
> wrote: ****
> > Radim,
> > Thanks for fixing the width issue.
> > Regarding layers with no titles and the need for treating the space like
> a
> > layer item, see http://hub.qgis.org/issues/3605. We've discussed this
> with
> > Marco Hugentobler back then and came up with a nice compromise.
> > Beyond being a regression as it stands (i.e. legends from 1.8 projects
> will
> > have visible vertical spacing issues), here's a simple scenario in
> picture:
> > http://hub.qgis.org/attachments/3161/legend-simple-scenario.jpg (the
> spacing
> > should be equal for all companies, as well as btween roads and railways.
> > Having no layer title is a way to regroup many layers under one layer
> name
> > (i.e. having 5 shapefile polygons representing different ago-industrial
> > crops might nicely be represented under one layer title even though the
> > items are in five different physical shapefiles).
> > Math
> > On Wed, Mar 13, 2013 at 5:31 PM, Radim Blazek <[hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=1>>
> > wrote:
> >> On Tue, Feb 19, 2013 at 4:48 AM, Mathieu Pellerin <[hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=2>>
> >> wrote:
> >> > Radim,
> >> > Following up on your implementation of the nice legend's multicolumn
> >> > feature. I've noticed two regression (one of which I've filed a bug
> >> > already).
> >> > 1) The right-side box spacing is now miscalculated as it fails to add
> >> > the
> >> > icon label space value. Issue 7099 (http://hub.qgis.org/issues/7099)
> has
> >> > been filed with more details and a accompanying screenshot.
> >> Fixed.
> >> > 2) There also was a regression in the way vertical spacing is
> calculate
> >> > between layer items and layers. An old issue, 3605, highlighted a
> >> > similar
> >> > visual problem which was fixed in revision 08c88575
> http://hub.qgis.org/projects/quantum-gis/repository/revisions/08c885759bd280339605ea07a221ab20f7dfdb75/diff/).
> >> > Long story short, layers with no titles are often used as part of a
> >> > group of
> >> > layer items. As such, the solution found in the cited revision was to
> >> > take
> >> > into account the layer item vertical spacing to the layer vertical
> >> > spacing.
> >> > The multicolumn appear to have regressed this. I can open an issue
> with
> >> > screenshots if necessary.
> >> Layers with no titles? Is it a hack to avoid the layer title to be
> >> drawn in the legend for single symbol layers? Wouldn't it be better to
> >> modify composer legend so that single symbol layers will be drawn
> >> without separated layer title above symbol and the layer title text
> >> will be used as the symbol label?
> >> Radim
> >> > Mathieu
> >> > On Sun, Nov 18, 2012 at 12:10 AM, Radim Blazek <[hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=3>>
> >> > wrote:
> >> >> On Wed, Nov 14, 2012 at 11:11 AM, Andreas Neumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=4>>
> >> >> wrote:
> >> >> > Hi,
> >> >> > Thanks to Radim we now have multi-column legends in print
> composer.
> >> >> Thanks to Régis and Agence de l'eau Adour as it was already
> mentioned
> >> >> by
> >> >> others.
> >> >> > This
> >> >> > was one of my long-time feature requests - but it never got to the
> >> >> > top
> >> >> > of my requests so that we could pay for the work.
> >> >> > Generally it works great, but I noticed two strange behaviors:
> >> >> > * when having only one column (default) - the background rectangle
> is
> >> >> > way too small, not covering the full bouding box of the legend
> >> >> Width? Fixed.
> >> >> > * when going beyong 4 columns, QGIS gets really slow, hangs or
> >> >> > crashes.
> >> >> Splitting of layers into columns is not that easy as it seems to be.
> >> >> It is a special sort of bin packing problem (NP-hard). Maybe it has
> >> >> its own name? I have used brute force because:
> >> >> - I thought that the number of layer will never be too big
> >> >> - implementaion of heuristic algorithm for such a marginal feature
> >> >> seemed to be overkill
> >> >> - suboptimal solution could look quite bad
> >> >> You proved immediately that I was wrong. How many layers do you
> have?
> >> >> 70 I have read somewhere? My original idea was to calculate number
> of
> >> >> possibilities first and decide if heuristic should be used. Now it
> >> >> seems a necessity.
> >> >> Maybe I am wrong and there is a simple solution? Well, I did not
> know
> >> >> at the beginning that I am going to solve combinatorial exercises.
> >> >> Regarding the crash, I was quite careful, using value() where there
> >> >> was minimum suspicion that it could run out of range. Many
> >> >> combinations should not mean allocation of a lot of memory, just
> more
> >> >> computational time. Only one combination is always evaluated at
> time.
> >> >> Does it seem to be a memory allocation problem or out of list
> bounds?
> >> >> Could you send me backtrace off list?
> >> >> Please follow/comment http://hub.qgis.org/issues/1841
> >> >> Radim
> >> >> > Did other test the new multicolumn legends?
> >> >> > Thanks Radim for your work!
> >> >> > Andreas
> >> >> > _______________________________________________
> >> >> > Qgis-developer mailing list
> >> >> > [hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=5>
> >> >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> >> [hidden email]<http://user/SendEmail.jtp?type=node&node=5040281&i=6>
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5040281&i=7>
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.n6.nabble.com/Multicolumn-legends-in-print-composer-tp5016207p5040281.html
> To unsubscribe from Multicolumn legends in print composer, click here.
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: RE: Multicolumn legends in print composer<http://osgeo-org.1560.n6.nabble.com/Multicolumn-legends-in-print-composer-tp5016207p5040290.html>
> Sent from the Quantum GIS - Developer mailing list archive<http://osgeo-org.1560.n6.nabble.com/Quantum-GIS-Developer-f4099106.html>at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130314/e4cfbfff/attachment-0001.html>
