[Qgis-developer] Editable checkbox for field widget definitions
Andreas Neumann a.neumann at carto.net
Mon Mar 18 03:05:09 PDT 2013
 The new editable checkbox for the field widget definitions is useful -
 but it behaves quite strange.
 If I set some widgets to "not editable" (checkbox unchecked) and then
 do some other widget changes and then return back to the field that
 wasn't editable before, it falls back to "editable". So either there is
 a field-index problem or some other reason that the checkbox set
 manually by the user falls back to the initial state.
 Can others please check if they can replicate this behaviour?
 Thanks,
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
