[Qgis-developer] Plugin Installer---running custom post install for a plugin
Sandro Santilli strk at keybit.net
Thu Mar 21 01:37:27 PDT 2013
On Wed, Mar 20, 2013 at 05:12:46PM -0800, Gary Sherman wrote:
> On Wed, Mar 20, 2013 at 3:00 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> > Hey Gary,
> > What are you trying to achieve by doing that?
> Mainly do a one-time configuration process such as setting up individual
> user config files.  I can envision other tasks that are required for the
> plugin to function, but only need to be executed once.
What if the user (accidentally or intentionally) removes the so-generated
configuration files ? Would it make more sense to make the effects of this
one-time process detectable to re-run when needed ?
--strk;
