[Qgis-developer] installing 1.9 - 174 - missing icons in toolbar
Duarte Carreira
DCarreira at edia.pt
Thu Mar 21 05:27:55 PDT 2013
Thanks Nathan. That solved it!
Duarte
De: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Enviada: quinta-feira, 21 de Março de 2013 11:57
Para: Duarte Carreira
Cc: qgis-developer at lists.osgeo.org
Assunto: Re: [Qgis-developer] installing 1.9 - 174 - missing icons in toolbar
This is due to the new SVG based icons. I had to reinstall qt4 from OSGeo4W in order to get the QtSVG libs to install.
Give that a go and see what happens.
- Nathan
On Thu, Mar 21, 2013 at 9:38 PM, Duarte Carreira <DCarreira at edia.pt<mailto:DCarreira at edia.pt>> wrote:
Hi there.
After making a clean install of 1.9 - 174 (before vector merge) I'm missing some icons in the toolbar, namely Pan Map to Selection, Toggle Editing, Save Layer Edits, and Current Edits.
I thought there was a themes folder in qgis, but I can't find one even in other installs where this problem doesn't occur.
So my question is: where are the icons stored and can I replace them with a complete set?
Thanks,
Duarte
Duarte Carreira
Diretor | Dep. Informação Geográfica e Cartografia
www.edia.pt<http://www.edia.pt>
Tel. +351 284315100<tel:%2B351%20284315100>
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer<http://www.edia.pt>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130321/75828242/attachment.html>
