[Qgis-developer] problem with feature request and updateFeature
Denis Rouzaud denis.rouzaud at gmail.com
Fri Mar 22 06:10:19 PDT 2013
Yes exactly
             f = QgsFeature()
             iter = vectorLayer.getFeatures( QgsFeatureRequest() )
             while iter.nextFeature( f ):
                 print f.id()
                 f.setAttribute( field, QVariant( 1 ) )
                 vectorLayer.updateFeature( f )
Prints only 1 id, commenting the last line prints all ids.
On 03/22/2013 01:56 PM, Nathan Woodrow wrote:
> Do you mean your loop is exited when you call updateFeature?
> Can you post your code.
> - Nathan
> On Fri, Mar 22, 2013 at 10:54 PM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
>     Hi all,
>     I am looping over features of a layer using new API
>     (QgsFeatureRequest).
>     If I modify a feature and do: layer.updateFeature(f), my loop is
>     broken.
>     Is this a normal behavior?
>     What should I do if I want to modify features during the loop?
>     Thanks
>     Denis
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130322/11f655bc/attachment-0001.html>
