[Qgis-developer] error running qgis master - sextante depends on psycopg2 - but this dependency isn't well known
William Kyngesburye woklist at kyngchaos.com
Tue Mar 26 06:35:04 PDT 2013
That's not actually what I meant - I have a ready-made package for OS X on my site (see sig below).
If you install from source blindly, I *think* it puts it in the system Python framework, not it's proper place /Library/Python/2.7/site-packages.
On Mar 25, 2013, at 10:38 PM, ariel_t wrote:
> Thanks! I followed your advice and downloaded the tar ball from
> http://initd.org/psycopg/tarballs/PSYCOPG-2-4/psycopg2-2.4.6.tar.gz,
> unzipped it, then followed the instructions in the INSTALL file. Now
> psycopg2 is installed under the OS X system Python, and I've since been able
> to install QGIS plugins that require psycopg2.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/error-running-qgis-master-sextante-depends-on-psycopg2-but-this-dependency-isn-t-well-known-tp5023977p5042883.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
