[Qgis-developer] Performance for selection on attribute table
Matthias Kuhn matthias.kuhn at gmx.ch
Thu Mar 28 02:00:49 PDT 2013
On Don 28 Mär 2013 09:49:17 CET, HAUBOURG wrote:
> Thanks guys,
> I also raised on list issues with redrawing triggered by selection (but also bad performance for "identify" highlights for big objects).  On that point, preventing extra refreshes (http://hub.qgis.org/issues/2596) and heading towards multithreading to let renderer use another process can help.
> Anyway, we have an issue here, since datasets keep growing, and user won't always know about filter in layer properties. I didn't test if "select at id" option did change something. I didn't catch either what you describe with 'plugable' indexes. What could it be exactly?
Plugable indexes mean, you'll be able to have a cache on a layer (or
maybe a data provider) later on, which can have several indexes on its
features (even written in python hopefully) which can then answer a
certain QgsFeatureRequest (if they're able to)
E.g. you can have an index on certain attributes and in case the index
knows, that is has e.g. all the features with column1 = 5 ready (due to
an earlier request), the backend will not be bothered. Or a spatial
index could be integrated to speed up rendering (e.g. when panning
around and drawing similar regions all the time).
Right now, the only index available is for feature ids.
Regards
> régis
> -----Message d'origine-----
> De : Matthias Kuhn [mailto:matthias.kuhn at gmx.ch]
> Envoyé : jeudi 28 mars 2013 07:44
> À : HAUBOURG
> Cc : qgis-developer at lists.osgeo.org
> Objet : Re: [Qgis-developer] Performance for selection on attribute table
> Hi Régis
> The attribute table is not using any providers indexes. And when thinking about it a couple of questions arise like stable syntax across providers (different providers need different SQL which either needs to be translated from QgsExpressions or written by the user). Then a request needs to also include not-yet-committed features. These need to be evaluated as well. In case the user directly specifies sql for the provider and not a QgsExpression this will pose some more problems.
> A new caching mechanism has been merged recently, but I don't expect any performance improvements yet. The new caching mechanism nevertheless supports plugable indexes, which I hope can help at least in part of these situations as soon as they are implemented.
> The only possibility to make use of the data providers indexes that I know of right now (apart from making views et al) is to provide a subset string in the layer properties, but that's most likely not what you want.
> Also, as mentioned by Denis Rouzaud, the rendering that takes when the selection changes place takes its bit of the performance. I remember, that somebody began a list of such unnecessarily triggered renders, but can't find it right now. I hope that in this area some work will be done as well.
> Kind regards,
> Matthias
> On Mit 27 Mär 2013 20:57:07 CET, Régis Haubourg wrote:
>> Hi dev's, I was notified some performance matters when dealing with
>> selections in attribute tables, by some users swithcing from arcgis to QGIS.
>> Indexes of datasource seem to be ignored for SQL selection and search.
>> This leads to very slow selections when dealing with large datasets.
>> Anyone confirms?  Is it really related to indexes or another bottleneck?
>> Is there any possible improvement ? Are providers working on
>> selections or is that all dealing with cache?
>> Thanks for your feedback ,
>> Régis
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Performance-for-selection-on-attri
>> bute-table-tp5043381.html Sent from the Quantum GIS - Developer
>> mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
