[Qgis-developer] QGIS master fail to import raster stretch from 1.8 project
Alexandre Neto senhor.neto at gmail.com
Thu Mar 28 03:41:36 PDT 2013
You are right, it's the second case you have described. The one also
described in
http://hub.qgis.org/issues/6809
I'm glad that the tickets was reopened since, IMHO, an effort should be
done to make users transition from 1.8 to 2.0 as comfortable as possible.
Thanks,
Alexandre Neto
On Thu, Mar 28, 2013 at 12:05 AM, Ramon Andiñach <custard at westnet.com.au>wrote:
> On 28/03/2013, at 6:33, Ramon Andiñach <custard at westnet.com.au> wrote:
> > On 27/03/2013, at 18:37 , Alexandre Neto wrote:
> >> Can anyone confirm that master version is now unable to correctly
> import rasters stretch from 1.8 projects, showing the raster area in total
> gray? To actual see the raster one needs to Strech histogram. I have tried
> using TIF and SID RGB.
> >> I did not have this problem before master update yesterday.
> >> I'm testing using QGIS 1.8 (f440b60) and QGIS 1.9 (4189f45), in Windows
> 7 64bit, installed via OSGEO4W.
> >> Alexandre Neto
> > Hi,
> > I'm slightly confused. Could you clarify for me?
> > If you mean that your 1.8 project has an image with "no stretch" applied
> and that shows as a grey box in 1.9, then yes this is known and there's an
> issue reported. I understand it has to do with there being some significant
> changes to the way vectors are handled in the new version. Once you've
> stretched the image in 1.9, you should be able to put it back to "no
> stretch" and still see it. http://hub.qgis.org/issues/6809.
> > If you mean that your 1.8 project has an image which "already has a
> stretch" applied that shows as a grey box in 1.9 then I think that's new.
> > I couldn't see this happening on a mac using 0005467 this morning, but
> will also check on a win7 box later.
> Sorry, second case works for me, even on windows (87265c7).
> -ramon.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130328/d4dfc937/attachment.html>
