[Qgis-developer] feature freeze exception
Tim Sutton lists at linfiniti.com
Sun Mar 31 22:34:57 PDT 2013
Hi
On Mon, Apr 1, 2013 at 2:14 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Borys,
> I would see this more as a bug fix then a new feature.
Yes same here, Borys this would fall under consistency and clean up
leading up to the release.
Regards
Tim
> - Nathan
> On Mon, Apr 1, 2013 at 8:44 AM, Borys Jurgiel <lists at borysjurgiel.pl> wrote:
>> Hi Tim, hi All,
>> Last time Martin switched the plugin manager to only use metadata.txt
>> instead
>> of __init__.py , and now I'm updating installer to use the same.
>> Old plugins without metadata.txt are not displayed in the manager, however
>> they are available in installer (because it doesn't know about the lack of
>> metadata.txt unless the plugin is installed), so it's important to mark
>> them
>> as invalid after install to explain to the user their state.
>> Because 'displaying plugins without metadata as invalid' can be recognized
>> as
>> a new feature and I won't manage to implement it in 15 minutes, I'd like
>> to
>> ask for freeze exception for this small feature. I believe it would be a
>> huge
>> regression if plugins without metadata.txt disapeared with no sign.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
