[Qgis-developer] Git help needed
Werner Macho werner.macho at gmail.com
Thu May 2 01:41:46 PDT 2013
assuming that you have commited something to your origin (your fork on
github)
you should first clean your local repo with upstream - to be in sync with
upstream
git reset --hard upstream/master
and then force your local to your origin..
git push origin +master
the bad thing is that you will loose all local changes .. but you did only
ask for cleaning not for saving your data ;)
and i found this solution also on stackexchange
http://stackoverflow.com/questions/8134960/git-how-to-revert-master-branch-to-upstream
kind regards
Werner
On Thu, May 2, 2013 at 10:34 AM, MORREALE Jean Roc
<jr.morreale at enoreth.net>wrote:
> Hi,
> Could a git expert tell me how to clean my repo ?
> The situation : my fork origin/master is synced with upstream/master but
> if I do a pull request, some old commits are taken into account even if
> they aren't relevant.
> The desired solution : wipe all my local history and get a "pure" copy of
> upstream as if I just forked, without deleting my actual github fork.
> Regards,
> Jean-Roc
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130502/00d28a30/attachment.html>
