[Qgis-developer] How to modify QGIS UI at start?
db-esm david at esmarkets.com
Fri May 3 10:39:47 PDT 2013
Hi Nathan,
Thanks for the help.
It's too late (for this project) for me to move up to the dev version right
now, but that could be very helpful in the future.
I assume when QGIS 1.9 is released, all this will "just work"?
Thanks again,
David
Nathan Woodrow wrote
> You will have to running the latest dev version of QGIS for this to work
> as
> --configpath is broken in 1.8.
> This is what you should do:
> start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis\bin\qgis-dev.exe
> --customizationfile "%cd%\QUANTU~1\Esm.ini"
> If you call the batch file rather then the exe it will set everything up
> for you
> "%OSGEO4W_ROOT%"\apps\qgis\bin\qgis-dev.bat--customizationfile
> the --configpath and --optionpath args just take a folder, there is no
> convention.  I am using app in my example just to keep it simple but it
> can
> be anything.
> - Nathan
> On Fri, May 3, 2013 at 11:52 PM, db-esm <
> david@
> > wrote:
>> This is from a .bat file:
>> start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis\bin\qgis.exe
>> --configpath
>> I notice in the example you mentioned that you are not using a file name
>> with --configpath, you're using only a path.
>> Is there a specific file name that must be used?
>> David
>> > David,
>> > Can you paste the command line call you are using.
>> > --configpath does work, I use it one of my projects here
>> > https://github.com/NathanW2/qmap/blob/master/src/loader_src/qmap.bat
>> > - Nathan
>> > On Fri, May 3, 2013 at 11:15 PM, db-esm <
>> > david@
>> > > wrote:
>> >> When I try to use "code" or "customizationfile" as a command line
>> option,
>> >> I
>> >> get an error message like:
>> >> "The layer C:\Users\Public\ThumbImage\--code is not a valid layer and
>> >> cant
>> >> not be added to the map"
>> >> The "--configpath" option doesn't result in an error message, but has
>> no
>> >> effect: the UI settings are still read from (and written to) the
>> Windows
>> >> registry.
>> >> Perhaps on Windows, QSettings always uses the registry now?
>> >> David
>> >> > Yes it works on all platforms.
>> >> > - Nathan
>> >> > On Thu, May 2, 2013 at 11:31 PM, db-esm <
>> >> > david@
>> >> > > wrote:
>> >> >> Does this work on Windows?
>> >> >> Sorry, I should have mentioned from the beginning that we're on
>> >> Windows.
>> >> >> David
>> >> >> > If you save the ini file out and edit it by hand.  It's just a
>> bunch
>> >> of
>> >> >> > true and false switches.  You can can then load QGIS using the
>> >> >> > --customizationfile your.ini option and it will change the UI on
>> >> load
>> >> >> > QGIS can also take a --code yourpythonfile.py that will run after
>> >> the
>> >> >> > project is loaded.
>> >> >> > - Nathan
>> >> >> > On Thu, May 2, 2013 at 5:22 PM, Marco Bernasocchi
>> >> >> > marco@
>> >> >> > >wrote:
>> >> >> >> On 05/01/2013 08:19 PM, db-esm wrote:
>> >> >> >>> Yes, but we need to have this happen automatically without
>> users
>> >> >> having
>> >> >> >>> to do
>> >> >> >>> it manually.
>> >> >> >>>  IIRC you can deploy a customization.ini file, it will be read
>> at
>> >> >> >>> startup
>> >> >> >> ciao
>> >> >> >>> View this message in context: http://osgeo-org.1560.x6.**
>> nabble.com/How-to-modify-QGIS-**UI-at-start-tp5050659p5050686.**html<http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050686.html&gt
>> >> >> >>> Sent from the Quantum GIS - Developer mailing list archive at
>> >> >> >>> Nabble.com.
>> >> >> >>> ______________________________**_________________
>> >> >> >>> Qgis-developer mailing list
>> >> >> > Qgis-developer at .osgeo
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer&gt
>> >> >> >> Marco Bernasocchi
>> >> >> >> http://opengis.ch
>> >> >> > _______________________________________________
>> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050959.html
>> >> Nabble.com.
>> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5051179.html
>> Nabble.com.
>> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5051188.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5051237.html
