[Qgis-developer] Size scale field not working with centroid fill
Alexandre Neto senhor.neto at gmail.com
Mon May 6 04:27:48 PDT 2013
Hi Mathieu,
thanks for your answer.
I don't think it's the same problem (although I have noticed it too), as
that issue only affect master, whether the issue I'm talking about affect
both 1.8 and master, but only in centroid fill (in polygon layers), in
point layer it works well.
Not sure if it's a bug, a not implemented feature, or simply a not intended
one.
Alexandre Neto
On Mon, May 6, 2013 at 12:15 PM, Mathieu Pellerin <nirvn.asia at gmail.com>wrote:
> Alexandre,
> Might be linked to this issue: http://hub.qgis.org/issues/7738  --
> centroid fill always use map unit even when set to millimetres.
> Mathieu
> On 6 May 2013 18:09, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>> Hello all,
>> Using "Size scale field" does not seam to be  working with centroid fill,
>> both in 1.8 and master. Is this intended?
>> Does anyone know if there is a feature\bug ticket for it? I could not
>> find one.
>> Alexandre Neto
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130506/007d130f/attachment.html>
