[Qgis-developer] Histograms huge
Paolo Cavallini cavallini at faunalia.it
Tue May 7 02:03:16 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 03/05/2013 19:38, Matthias Kuhn ha scritto:
> Because I was lacking a better idea, I just filled in
> * the maximum value of any attribute for histograms
in my case, it selected the attribute with the max value, but it did not autofill the
max value.
I think the correct behaviour would be:
* the user should select the attribute(s) to plot (so this should go to the top of
the form, as it is now the only thing the user has necessarily to deal with)
* the max value should be autofilled with the highest value of the variables selected
>> * It would be nice that on reopening the user will find the last used tab, instead of
>> going back to the first one.
>> * The default for scale dependent visibility should match those on the General tab
>> rather than being -1.
> All done. Thank you for the inputs.
> I'd be glad if you could give it a short test.
Done, thanks a lot. Much more usable now, I believe.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlGIw1QACgkQ/NedwLUzIr7JZACggwkumeEhJ3igyjWwAdB0xXyE
hOIAniMwnT45OF38CIM7Tx6Y60BcwiQS
=MDnH
-----END PGP SIGNATURE-----
