[Qgis-developer] Possible memory leak in rendering code
Nyall Dawson
nyall.dawson at gmail.com
Tue May 14 01:55:10 PDT 2013
On 23 April 2013 19:05, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> How comes that the same feature works fine for some but is broken for
> others?
> When I have it on (using a combination of Postgis, WMS and GeoTiff) I
> often have redraw issues and the layer toggeling often fails. Layers are
> not drawn, but appear to be on with the checkbox in the layer tree or
> vice versa. I think the main problem is when also using WMS sources.
Now that you've mentioned this I'm noticing it all the time. I've
ended up switching off render caching and am OK if it gets removed
now.
Nyall
