[Qgis-developer] Adding labels
Benoît Laurent blaurent at heurisis.eu
Tue May 14 08:30:59 PDT 2013
Many thanks Larry !
I eventually installed the weekly build. I used the test script you
mentionned and it works great ! I had struggled for two days.
Thank you again.
Benoît
> Hi Benoît ,
> On Tue, May 14, 2013 at 3:18 AM, Benoît Laurent <blaurent at heurisis.eu
> <mailto:blaurent at heurisis.eu>> wrote:
>     Hello,
>     Did I ask my question in the right place ? Can someone help me ?
>     Thank you in advance.
> If you are using a master branch build, you can script the new
> labeling engine via Python. The following test script has some sample
> code [1].
> [1]
> https://github.com/qgis/Quantum-GIS/blob/master/tests/src/python/test_qgspallabeling.py
> Regards,
> Larry
>     Regards,
>     Benoît
>>     Hello,
>>     I am not sure to be on the right place to ask my question. If
>>     not, I beg your pardon.
>>     I am trying the write a Python script that :
>>     - load a set of shapefile ;
>>     - automatically add labels based on a field ;
>>     - set the color, the size, etc. of my points.
>>     For the moment, I can load the shapefiles. I also succeded in
>>     labeling but I am not able to move the labels manually once
>>     created. Here is my piece of code for labeling :
>>             def add_label(self, layer):
>>                     layer.enableLabels(1)
>>                     myLabel = layer.label()
>>                     myLabel.setLabelField( QgsLabel.Text, 17)
>>     myLabel.layerAttributes().setAlignment(4)
>>     Is there an other way of doing this ? Is there samples of code ?
>>     Benoît
>>     _______________________________________________
>>     Qgis-developer mailing list
>>     Qgis-developer at lists.osgeo.org
>>     <mailto:Qgis-developer at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Heurisis <http://www.heurisis.eu>
>     Benoît LAURENT Consultant Optimisation
>     9, rue Alexandre Fleming, 49066 Angers CEDEX
>     Portable +33 (0)6 28 03 81 32 e-mail : blaurent at heurisis.eu
>     tel : +33 (0)9 54 30 41 14
>     <tel:%2B33%20%280%299%2054%2030%2041%2014> site : www.heurisis.eu
>     <http://www.heurisis.eu/>
>     	Visitez le site www.optiscolaire.fr <http://www.optiscolaire.fr>
>     éco : Avant d’imprimer ce mail, pensez à l’environnement
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Signature_Benoit_Laurent
tel : +33 (0)9 54 30 41 14 site : www.heurisis.eu <http://www.heurisis.eu/>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0001.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0005.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0006.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0007.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0008.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130514/d2bae828/attachment-0009.gif>
