[Qgis-developer] Labeling gui redesign branch ready
Tim Sutton lists at linfiniti.com
Sat May 18 13:31:36 PDT 2013
Hi Larry
On Sat, May 18, 2013 at 10:10 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hi,
> I think the branch I have been working on for the labeling gui redesign and
> expression-based data definitions is ready to merge [0]. Here is the commit
> message:
> Update labeling gui and add expression support as data defined value
> - Add QgsDataDefined class
> - Add QgsDataDefinedButton class
> - Add data defined Python support
> - Add standalone SVG selector dialog to QgsSvgSelectorWidget class
> - Fix for #4607, show only pertinent fields when setting a data defined
> value
> - Fix for #5048 and #5049, data defined settings are literally used
> - Fix for #5726, number formatting does not work for expressions
> - Fix for #7755, using bufferSize to enable/disable label buffer is
> confusing
> - Fix for #7779, labels do not register in label collision engine; and for
> #4719, inactive options in labeling dialog
> - Prepare label text's expression upfront when preparing layer; makes
> rendering much faster
> - Change name of 'feature obstacles' to appropriate terminology
> (Due to my workflow between 3 computers and constant rebasing, my branch was
> squashed down to one commit; sorry about that).
> I would like to merge this branch sometime this weekend, but will hold off
> if someone objects. I can create a pull request if needed.
> The goal of this redesign was to add expression-based data definitions, make
> a small data defined tool button with visual feedback that can be used
> in-line in any form layouts [1, 2], and bring all the new labeling features
> to a finished looking state for 2.0. Also, the redesign was done with the
> intent that it integrates well with an eventual move to rule-based labels
> and styles (2.0 >).
> The work was mostly financed through a generous donation by a community
> member (thank you for the support).
Many thanks to the donor!
> Notes:
> There were 83 labeling data defined options added or updated, with well over
> 100 basic label configuration combinations that need unit tests. Full data
> defined labeling Python support was just completed in this branch, so now a
> complete test suite for can finally be built for labeling. Currently there
> are no tests, so anyone who can help manually test this update would be
> greatly appreciated.
> Enabling a label buffer is no longer triggered by it size. I have added code
> to compensate where it was used by older projects. Please let me know ASAP
> if there is an issue with any layer-level or data defined buffers in any new
> or converted projects.
> The implementation of quadrant offset for 'Over point' has be changed to an
> enum setup. This feature was not in 1.8, but may have been set by users
> working with 1.9 projects. I can add code to update projects from 1.9 to
> 2.0, but it seemed extraneous given it was a change between releases. Users
> with 1.9 projects will have to manually reset quadrant choices.
I dont think it is consistent with the goal of cleaning the code base
for 2.0 to have migration code for 1.9 to 2.0. USers on 1.9 should
understand that things are in flux until 2.0 comes out. So -1 from me
for that.
+1 from me for you to go ahead and merge. We have been testing your
changes here and they are absolutely awesome. I would really love to
see a good unit test for this follow.
Regards
Tim
> The code for migrating index-based data defined project settings to
> name-based ones was updated. My tests show it is OK, but please contact me
> ASAP if you find opening any 1.8 project seems to have issues.
> [0] https://github.com/dakcarto/Quantum-GIS/tree/labeling-gui_redesign
> [1] http://drive.dakotacarto.com/qgis/labeling-redesign_btn-tool-tip.png
> [2] http://drive.dakotacarto.com/qgis/labeling-redesign_btn-menu.png
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
