[Qgis-developer] State of Spatialite 4.0 and GDAL 1.10 for QGIS 2.0?
Cline, Royce L. rcline at nd.gov
Tue May 21 13:42:35 PDT 2013
The other issue I have had with SpatiaLite 4 is with DB Manager. DB Manager does not recognize geometry for a table in a Spatialite 4 created database (new spatial metadata). Displays the same as a table without geometry. If the database was created with Spatialite 3 or converted to a version 3 database with spatialite_convert, then it will show the table as having geometry. It would appear that DB Manager is not testing whether the database containing the table is using the new or old version of the spatial metadata.
Royce
On May 21, 2013, at 2:44 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Larry,
> On Tue, 21. May 2013 at 13:14:00 -0600, Larry Shaffer wrote:
>> Is anyone using QGIS master branch with Spatialite 4.0 successfully?
> The submitter apparently is - it's just that it doesn't seem to work with empty
> tables.
>> Same questions for GDAL 1.10. Are there issues within the QGIS codebase
>> concerning its use that would cause it not to be recommended for 2.0?
> No.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
