[Qgis-developer] QGIS Server - GetPrint with a composer containing HTML block causes segfault
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed May 22 00:47:11 PDT 2013
Hi Michael
I also encountered that problem. Unfortunately, it seems that QWebKit
requires a running x-server. So it won't be possible to use html items
in server projects (or you can run an x-server and set the DISPLAY
variable in the fcgi conf).
Regards,
Marco
On 22.05.2013 09:43, kimaidou wrote:
> Hi list
> I have tried it with today's qgis master.
> I have a very simple project with one shapefile containing 3
> polygones. I created a composer with a map. GetPrint request works
> fine with it. If I add an HTML block in the composer (refering to one
> HTML file or not), the getPrint request raises a segfault.
> Apache error log is the well-known :
> "Premature end of script headers: qgis_mapserv2.fcgi"
> By the way, I compiled QGIS with -DCMAKE_BUILD_TYPE=debug , but I do
> not know where I can find complet log for QGIS Server. Is there a file
> where I can get complete log for QGIS Server ?
> I can provide a sample project if needed. I have not found a ticket in
> the hub, so I will fill one, but I would prefer to do so with a
> self-explaining log.
> Michael
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130522/e00e39a2/attachment.html>
