[Qgis-developer] QGIS Server - performance issue in master since one week (after df19fe5e04b0c2ae8f1b13000099715559e6bd50 )
kimaidou kimaidou at gmail.com
Wed May 22 07:50:49 PDT 2013
I checked other commits :
pyqgis-console] allow to disable automatic parentheses insertion from
settings (commit 942d6bfa5d5e9cc7471efcd34717613fa6a8b7db )  -->
performance issues
Fix wmsserver: Do not manipulate maplayerregistry directly (commit
df19fe5e04b0c2ae8f1b13000099715559e6bd50 ) --> Good perfs
So the problem is in between. I continue testing commits
2013/5/22 kimaidou <kimaidou at gmail.com>
> Hi devs
> There seems to be a performance issue in QGIS Server. I tried to compile
> different versions and got the following results :
> QGIS master df19fe5e04b0c2ae8f1b13000099715559e6bd50 --> works as expected
> = pretty fast ;)
> QGIS today's master -> a lot of performance issues. I get a lot of the
> following errors: http://paste.ubuntu.com/5690303/
> So there is a commit in between which raises the issue. I can go on the
> process of compiling every commit to find the one which triggers the issue,
> unless someone knows
> Anyone confirms ?
> Regards
> Michael
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130522/3ede5612/attachment.html>
