[Qgis-developer] QGIS Server - performance issue in master since one week (after df19fe5e04b0c2ae8f1b13000099715559e6bd50 )
Matthias Kuhn matthias.kuhn at gmx.ch
Wed May 22 08:57:45 PDT 2013
Hi Michael,
It's probably the commit you identified:
Fix wmsserver: Do not manipulate maplayerregistry directly
I'm almost sure if you revert this one and commit
35de29df9bea0a8d36d54aec677df054d7cd37ba it will run fine.
I'll have a look and revert these in case I don't find a solution to
get around this.
As I don't have a mapserver running here, could you assist with testing
if I have a possible fix ready?
Regards,
Matthias
On Mit 22 Mai 2013 17:51:01 CEST, kimaidou wrote:
> Thanks Jürgen for this great tip
> I almost trapped the "vicious" commit !
> Following commit has BAD Server perfs
> Following commit has GOOD Server perfs
> Merge pull request #591 from ccrook/delimited_text_to_core …
> 91f3ceab26013d6c97a0047c344f5e2570df34c3
> I tried to compile commits between these 2 above but cannot due to
> compilation errors.
> I let users with better C++ skills and good QGIS Server knowledge find
> the problem
> Thanks for any further help regarding this regression
> Michael
> 2013/5/22 Jürgen E. <jef at norbit.de <mailto:jef at norbit.de>>
>     Hi Michael,
>     On Wed, 22. May 2013 at 16:14:50 +0200, kimaidou wrote:
>     > So there is a commit in between which raises the issue. I can go
>     on the
>     > process of compiling every commit to find the one which triggers the
>     > issue, unless someone knows
>     I don't.  But git bisect will probably take you there pretty quick. ;)
>     Jürgen
>     Jürgen E. Fischer         norBIT GmbH               Tel.
>     +49-4931-918175-31
>     Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>     +49-4931-918175-50
>     Software Engineer         D-26506 Norden
>     http://www.norbit.de
>     committ(ed|ing) to Quantum GIS                         IRC: jef on
>     FreeNode
>     norBIT Gesellschaft fuer Unternehmensberatung und
>     Informationssysteme mbH
>     Rheinstrasse 13, 26506 Norden
>     GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
