[Qgis-developer] [Qgis-user] New Icons - difficult to "read"
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri May 24 01:59:13 PDT 2013
+1
i.e. The difference between the "Add PostGIS layers" and "Add SpatiaLite
layers" is that one has a regular cylinder and the other has a fat-waisted
hour-glass cylinder - about 20-30 pixels are different in an icon that's
got 1024 pixels! I have to look at them in detail to see the differences.
And there's still MSSQL and Oracle icons to be created in the new schema
which using this system will only confuse things more.
Don't get me wrong, I like the style of the new icons, but they're really
hard to visually differentiate.
I did a quick google and came across this:
http://turbomilk.com/blog/cookbook/icon_design/10_mistakes_in_icon_design/
The QGIS icons do all of the top three things.
Jonathan
On 24 May 2013 09:27, skampus <stefano.campus at regione.piemonte.it> wrote:
> that could be a useful option.
> sincerely, from my point of view, many icons are
> unreadable/undistinguishable so i click them correctly only because now i
> remberer relative position
> http://osgeo-org.1560.x6.nabble.com/Re-Qgis-user-New-Icons-difficult-to-read-tp5055427p5055467.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130524/2b35f9b9/attachment.html>
