[Qgis-developer] Layers rendering order swapped (behavior change)
Giovanni Manghi
giovanni.manghi at faunalia.pt
Fri May 24 02:44:22 PDT 2013
> I saved a simple project with 3 layers from 1.8.0.
> Opening it with current master (commit:83445af) renders those
> 3 layers upside down (layer on top in the layer manager is
> rendered at the bottom in the map canvas).
> Moving layers around confirms the behavior: you have to move
> point layers at the bottom in order for them to NOT be covered
> by lineal layers.
> Is this intentional ?
you may want to add your notes here
http://hub.qgis.org/issues/7623
