[Qgis-developer] [Qgis-user] New Icons - difficult to "read"
Marco Bernasocchi
marco at bernawebdesign.ch
Fri May 24 05:23:47 PDT 2013
Agree as well with Werner and Anita.
It is just matter of a short adaptation period.
Ciao
On 05/24/2013 01:34 PM, Anita Graser wrote:
> Hi,
> -1. I agree with Werner. Having used the "gis" icon set for many months,
> I have problems using the old ones. That's just how the human mind works.
> Let's improve the "gis" icons where it makes sense but let us focus or
> work on one set.
> Best wishes,
> Anita
> On Fri, May 24, 2013 at 1:14 PM, Werner Macho <werner.macho at gmail.com
> <mailto:werner.macho at gmail.com>> wrote:
> Hi!
> -1 for keeping the old Icons..
> I'd rather vote to probably leave them for 2.0 but get rid of them
> afterwards.. It does not make any sense to have different sets of
> icons ..
> And as GRASS is using the same icon set in their GUI it does indeed
> make sense to use it probably in every open source GIS ..
> I know that the first time might be hard but that"s just the usual
> human behaviour of refusing new things.
> But for e.g. I am working with the new icon set since a very long
> time (to use GRASS and QGIS in parallel) and I can find everything
> at once but rather have some kind of problems when I switch to the
> old ones..
> So I know that I could adapt myself to the old iconset within a few
> days .. It"s just human that every "more work" you have to do gets
> refused at first regardless of the advatnages it might bring later
> So maybe for a period of migration I"d leave the old icons inside
> but definitely not for 2.1 or later ..
> OF course that all is just my personal experience and opinion
> kind regards
> Werner
> On Fri, May 24, 2013 at 12:15 PM, Duarte Carreira <DCarreira at edia.pt
> <mailto:DCarreira at edia.pt>> wrote:
> I would like to ask the “powers that be” to keep the old and
> trusted icons. They never failed me and the gui is quite
> uplifting. The new set may be technically better but is not as
> friendly to users.
> Please keep both.
> Duarte
> *De:*Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk
> <mailto:jonathanmoules at warwickshire.gov.uk>]
> *Enviada:* sexta-feira, 24 de Maio de 2013 09:59
> *Para:* skampus
> *Cc:* qgis-user at lists.osgeo.org
> <mailto:qgis-user at lists.osgeo.org>;
> qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> *Assunto:* Re: [Qgis-user] [Qgis-developer] New Icons -
> difficult to "read"
> +1
> i.e. The difference between the "Add PostGIS layers" and "Add
> SpatiaLite layers" is that one has a regular cylinder and the
> other has a fat-waisted hour-glass cylinder - about 20-30 pixels
> are different in an icon that's got 1024 pixels! I have to look
> at them in detail to see the differences. And there's still
> MSSQL and Oracle icons to be created in the new schema which
> using this system will only confuse things more.
> Don't get me wrong, I like the style of the new icons, but
> they're really hard to visually differentiate.
> I did a quick google and came across this:
> http://turbomilk.com/blog/cookbook/icon_design/10_mistakes_in_icon_design/
> The QGIS icons do all of the top three things.
> Jonathan
> On 24 May 2013 09:27, skampus
> <stefano.campus at regione.piemonte.it
> <mailto:stefano.campus at regione.piemonte.it>> wrote:
> that could be a useful option.
> sincerely, from my point of view, many icons are
> unreadable/undistinguishable so i click them correctly only
> because now i
> remberer relative position
> http://osgeo-org.1560.x6.nabble.com/Re-Qgis-user-New-Icons-difficult-to-read-tp5055427p5055467.html
> Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com.
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> This transmission is intended for the named addressee(s) only
> and may contain sensitive or protectively marked material up to
> RESTRICTED and should be handled accordingly. Unless you are the
> named addressee (or authorised to receive it for the addressee)
> you may not copy or use it, or disclose it to anyone else. If
> you have received this transmission in error please notify the
> sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to
> recording and/or monitoring in accordance with relevant legislation.
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Marco Bernasocchi
http://opengis.ch
