[Qgis-developer] Fwd: [GRASS-dev] [Proj] Improvements to geod and invgeod
Paolo Cavallini
cavallini at faunalia.it
Sun May 26 06:47:25 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
Is this of some interest for us too?
All the best.
- -------- Messaggio originale --------
Oggetto: [GRASS-dev] [Proj] Improvements to geod and invgeod
Data: Sun, 26 May 2013 01:00:16 -0700 (PDT)
Mittente: Helmut Kudrnovsky <hellik at web.de>
A: grass-dev at lists.osgeo.org
fyi
taken from http://lists.maptools.org/pipermail/proj/2013-May/006602.html
geod and invgeod, programs for performing geodesic calculations, have
been part of proj.4 since at least 1995. There are several problems
with them:
* the overall accuracy is limited;
* the results of inverse calculations are sometimes wildly wrong;
* there's no documented API for the geodesic capabilities;
* there's no provision from computing various quantities associated with
geodesics (in particular the area of a geodesic polygon).
These problems will be addressed in the next release of proj.4 with the
inclusion of the algorithms for geodesics from GeographicLib. These are
documented in
C. F. F. Karney,
Algorithms for geodesics,
J. Geodesy 87(1), 43-55 (Jan. 2013)
http://dx.doi.org/10.1007/s00190-012-0578-z
Addenda: http://geographiclib.sf.net/geod-addenda.html
Points to note:
* Several libraries that depend on proj.4, e.g., GRASS, use approximate
methods for computing polygonal areas. They can now use proj.4 to
compute areas accurately.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlGiEm0ACgkQ/NedwLUzIr7RTwCgronEzHfRhY3LXuQcDASGhorX
u20AniV9i5qYQI2aZswpB38ZCabaH2fk
=+9c6
-----END PGP SIGNATURE-----
