[Qgis-developer] Delimited text issues and ideas
Chris Crook ccrook at linz.govt.nz
Sun May 26 16:10:33 PDT 2013
Hi Alexander
Quite agree that it is still not user friendly.  I have a patch which allows multiselect in the dialog.  It is a little unclean in that it may ask for the coordinate system for each file (depending on current settings), but that would require changes outside of the provider I think.
I've not pushed this to master - I think it should wait till after 2.0 now as it will add a few more translations.  That said, it would be nice to have it consistent with the AddVectorLayer dialog.  It is available at..
https://github.com/ccrook/Quantum-GIS/tree/csv_multi_select
Cheers
Chris
________________________________________
Sent: 27 May 2013 04:22
To: Chris Crook
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Delimited text issues and ideas
Hi Chris,
2013/5/26 Chris Crook <ccrook at linz.govt.nz>:
> Good thought.  If you are loading several files at the moment QGIS should remember the settings between files, so you only have to select them and add them, not redo the settings.  But it is still a lot of clicks for each file.
Right, now settings are saved between files, but users still need to
select file one by one. Not userfriendly IMO.
> 1) Once a list of files are selected from browse buttin, how to display the selected file names in the text box.  Would this become a drop down list? Or would we use a list of file names with a separator (and if so, what separator)?  Should the text box allow wild card file names?  There must be a precedent for this somewhere, just can't think of one straight away.
Why not show full file names with separator like semicolon? If I'm not
wrong, same approach used in GDALTools plugin when
multiple files selected.
> 2) Handling of layer names for each file.  Could just be the file name (which is the default layer name anyway).  Could have some way of entering the filename into a string (eg <filename>).  Whatever is used it should be consistent with the rest of QGIS (expression builder? not sure there is anywhere variables are used in this way), and obvious for the user...
For me using filename as layer name is fine
Alexander Bruy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
