[Qgis-developer] Python error in master
Paolo Cavallini cavallini at faunalia.it
Tue May 28 10:28:12 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 28/05/2013 18:39, Larry Shaffer ha scritto:
>> I just noticed you mentioned 'Packages from debian-nightly, sid,' which I assume
>> means for QGIS. If the sip.so module is not part of those packages (I would suspect
>> not), maybe just upgrading your local sip install will fix the issue.
>> Larry
>>     I 'fixed' my sip compile error by deleting my build directory's contents and
>>     doing a fresh CMake configure and build.
Hi Larry,
thanks for your reply. My situation is a bit different:
* I have only Debian testing and unstable boxes, clean and up to date
*  python-sip 4.13.3-2
* I installed qgis from jef nightly repo
So I recompiled (dpkg-buildpackage) it myself, but now I get:
qgis.bin: /build/buildd-sip4_4.13.3-2-amd64-4XEr_m/sip4-4.13.3/siplib/siplib.c:6400:
sip_api_can_convert_to_enum: asserzione "(((td)->td_flags & 0x0007) == 0x0003)" non
riuscita.
Obviously there must be a problem with sip somewhere.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlGk6SwACgkQ/NedwLUzIr56QACeOIL08SjiKtnR8PPD2vk2okDL
n1IAoIkqBRhx8jS8sB+c/nhxl6zRluat
=DCLF
-----END PGP SIGNATURE-----
