[Qgis-developer] QGIS Server - GetPrint request does not respect text boxes size and position if dynamic content passed
kimaidou
kimaidou at gmail.com
Tue May 28 11:42:51 PDT 2013
Hi again
I reply here because I have just noticed a very cool new feature in QGIS
composer. You can add an HTML box, give a file stored in the disk
containing the HTML code to display in the box. I knew this option. What I
did not notice was the ability to let QGIS create as many pages as
necessary to dispplay the full content of the HTML file related to the box.
So instead of passing long parameter to getPrint text boxes to dynamically
replace the content (html rendered or not), I could use this feature
instead. What is missing for me right now to achieve this goal :
* be able to pass the HTML file path via a parameter. We could use the id
of the HTML item in the composer.
* be able to make it work in getPrint : I managed to create a PDF from QGIS
with the HTML content from a file, but could not via QGIS Server: the HTML
block stays empty. This is not because of X server, because I can use HTML
text for text blocks via the "fake" X server.
Any comment appreciated.
Good evening
Michael
2013/5/28 kimaidou <kimaidou at gmail.com>
> 2013/5/28 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>> >So for me, simply removing the adjustSizeToText call would be enough.
>> Or we have to make sure this method does the job correctly, which may be a
>> bit hard to implement : we need to avoid to have >collision with other
>> composition items, etc.
>> The problem is if the client provided text does not fit into the
>> predefined label box.
> I agree, but it is better than "now", and quite logical to me : if the
> content does not fit, only the part which fits is visible. This allows the
> output PDF to be like the author wanted to, with the position and size of
> each text box as set in the Composer. And above all, text wraps correctly
> without dynamic resize. We could try to add an option "max length" for the
> text boxes which could be advertised in the getCapabilities ? This way the
> client could warn the user whenever he tries to use a text which too many
> characters ?
>> It would be good to combine dynamic resize capabilities with line breaks
>> somehow.
> I think dynamic resize should be used only if we can use it with line
> breaks.Better respect the position and size defined by the user in QGIS
> composer than having a text item which get so long that it get out of the
> composer limits.
>> I'm open for suggestions.
> Thanks, and please forgive my english which sometimes prevents me from
> souding moderate enough. I know that giving ideas is easy and developping
> features is harder !
> Some suggestions (I am thinking out loud...)
> * new option with max text length, advertised in the getCapabilities
> * linked text boxes. In softwares like Adobe Illustrator, or Scribus
> (open-source), you can link serveral text boxes, so that the text is
> written is the first box then in the linked one if the content does not fit
> the first one.
> * If "linked" text boxes is implemented, the killer feature would have to
> dynamically generate new pages with linked text boxes so that all the
> content is written in as many boxes as necessary to have the full content
> written down.
> Sincerely
> Michael
>> Marco
>> On 28.05.2013 11:53, kimaidou wrote:
>> Hi
>> I just made a small test and commented the line
>> currentLabel->adjustSizeToText();
>> Then recompile QGIS master and tested it with a classical text box (not
>> html rendered) with a long text.
>> I personnaly prefer the behaviour when this method is not called : the
>> text box keep the size set by the user in QGIS. And the text wraps when it
>> reaches the right side of the Box. I even tried with "HTML rendered" on
>> (and my fake X Server running), and it worked well too.
>> At the contrary, when adjustSizeToText is used, the box is transformed
>> in a one line box, which goes to the right of the entire composition (out
>> of it) : text does not wrap.
>> So for me, simply removing the adjustSizeToText call would be enough. Or
>> we have to make sure this method does the job correctly, which may be a bit
>> hard to implement : we need to avoid to have collision with other
>> Regards
>> Michael
>> 2013/5/28 René-Luc D'Hont <rldhont at gmail.com>
>>> Hi Marco
>>>> I guess yes. 'adjustSizeToText()' works for text, not html. Html
>>>> support for composer label was added recently to the composer label class.
>>>> Please adapt the relevant lines to work with html labels too.
>>> I'll adapt it
>>>> >Question for Marco, Why removed label, if the request doesn't define a
>>>> value ? Why not used the default value ?
>>>> The idea was that the web client has the possibility to remove an
>>>> advertised text label completely if it is not used. E.g. if a composition
>>>> defines a text item with id 'author', the web client can simply ignore it
>>>> if it does not want to have author's name printed. Note that the labels
>>>> without ids are not removed as they are considered to be fix, so not
>>>> subject to client text replacement (original meaning of label id was that
>>>> this text item is subject to text replacement by web client. Later, the id
>>>> has been generalized as an id for every item type).
>>>> Another possibility would be to remove the item only if the client
>>>> gives an empty text and use the default text otherwise. What do you think?
>>> I prefer to remove the label only if the user gives an empty text.
>>> Can I do it ?
>>> Regards,
>>> René-Luc
>>> On 27.05.2013 22 <27.05.2013%2022>:23, rldhont wrote:
>>>> Hi Marco and other devs,
>>>>> In src/mapserver/qgsconfigparser.cpp:530 we can read :
>>>>> //replace label text
>>>>> foreach ( QgsComposerLabel *currentLabel, composerLabels )
>>>>> QString title = parameterMap.value( currentLabel->id().toUpper() );
>>>>> if ( title.isEmpty() )
>>>>> //remove exported labels not referenced in the request
>>>>> if ( !currentLabel->id().isEmpty() )
>>>>> c->removeItem( currentLabel );
>>>>> delete currentLabel;
>>>>> continue;
>>>>> currentLabel->setText( title );
>>>>> This code is used to draw composer label with value defined by the
>>>>> QGIS WMS Server Request GetPrint.
>>>>> The bug defined in the issues #7894 http://hub.qgis.org/issues/7894is probably du to the method adjustSizeToText()
>>>>> Someone can confim it ?
>>>>> Regards,
>>>>> René-Luc D'Hont
>>>>> 3Liz
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Dr. Marco Hugentobler
>>>> Sourcepole - Linux & Open Source Solutions
>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>> Technical Advisor QGIS Project Steering Committee
>> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130528/f2dd188a/attachment.html>
