[Qgis-developer] New Icons - difficult to "read"
Anita Graser anitagraser at gmx.at
Tue May 28 12:25:28 PDT 2013
We used to have a hand icon:
http://www.flickr.com/photos/38241992@N06/4090679956/
Wonder if it still exists somewhere. But I admit, it wasn't too good :)
Best wishes,
Anita
On Tue, May 28, 2013 at 5:45 PM, Antonio Locandro <
antoniolocandro at hotmail.com> wrote:
> Just to reinforce the point raised
> The pan icon currently in Master are four arrows which are more associated
> with moving a graphic or a nudge, I would think the most well known symbol
> for that would be the famous little hand to pan
> Cheers
> *Ing. Antonio Locandro*
> Tegucigalpa, Honduras
> From: jonathanmoules at warwickshire.gov.uk
> Date: Tue, 28 May 2013 15:55:17 +0100
> To: anitagraser at gmx.at
> CC: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] New Icons - difficult to "read"
> Hi Anita,
> I think we have to be fair and recognize that a GIS is a little more
> complex than a web browser and will always have more buttons. Many
> functions which have only one meaning in a simpler application can have
> different meanings in a GIS depending on context. To simply assume the
> context from the placement in a certain toolbar could raise other issues.
> Fair point, but that's why I also compared other GIS's where I could
> (ArcGIS, MapModeller (FME Data Inspector uses the refresh circle but
> doesn't have a back/forward feature) and noted that they hold the same
> convention.
> Also, that was only one single example, there are others.
> These days people *expect* certain icons for certain things. To use a
> different icon throws away the years of pre-training the user will have
> already have using other applications that stuck to the convention.
> I don't think I've ever seen a single application that had 10 icons that
> were mostly the same before in the same that the magnifying glass ones in
> QGIS 2.0 are.
> Regards,
> Jonathan
> On 28 May 2013 11:11, Anita Graser <anitagraser at gmx.at> wrote:
> Hi,
> On Tue, May 28, 2013 at 11:23 AM, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
> +1 for unified data adding button. From a use-perspective there's no good
> reason that raster adding should be separate from vectors for instance
> In depth example: take the Back, Next, and Refresh view icons. The new
> QGIS icons all have a magnifying glass behind them (I can barely make out
> the "refresh" circle). Why? In comparison, I have four web-browsers in
> front of me, all have these buttons and all of them are simple
> arrows/refresh circles. None of them have a picture of a web-page behind
> them.
> ArcGIS and MapModeller both use simple arrows/circles too. MapInfo doesn't
> seem to have this functionality.
> At this point these icons are standard conventions, but the QGIS 2.0
> iconography makes that part only 1/6th of the actual icon, instead giving
> prominence to a magnifying glass that's entirely unnecessary.
> While I agree to some degree (+1 for unified data adding button), I think
> we have to be fair and recognize that a GIS is a little more complex than a
> web browser and will always have more buttons. Many functions which have
> only one meaning in a simpler application can have different meanings in a
> GIS depending on context. To simply assume the context from the placement
> Best wishes,
> Anita
> Qgis-developer mailing list
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> _______________________________________________ Qgis-developer mailing
> list Qgis-developer at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130528/8a412855/attachment-0001.html>
