[Qgis-developer] Updating core plugins
Victor Olaya volayaf at gmail.com
Tue May 28 22:33:28 PDT 2013
Thanks!
2013/5/29 Borys Jurgiel <lists at borysjurgiel.pl>:
> Dnia poniedziałek, 27 maja 2013 o 20:44:01 Victor Olaya napisał(a):
>> > Yes, non-core plugin overrides the core one (just because of the Python
>> > path order), so the only thing you can do is to make the core SEXTANTE
>> > version higher - at least QGIS will warn about the override and suggest
>> > manual uninstall.
>> Borys, I think this is not working. I have received reports of people
>> having SEXTANTE 1.0.9 interfering with the core 1.1 version, and I
>> tested it myself. If you have a plugin in .qgis2, it will override the
>> core one (as you mention), but no warning is produced.
> You're right, there is a bug. I'll fix it next week.
