[Qgis-developer] SIP API Update
Nathan Woodrow
madmanwoo at gmail.com
Thu May 30 19:41:35 PDT 2013
Etienne,
If self.attrStr() is something like QVariant(value) then you need to remove
the QVariant() bit call.
- Nathan
On Fri, May 31, 2013 at 12:39 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
> Yeah they both return QVariant but that is auto converted to a Python
> object by SIP.
> Not sure what is going on there I'll look into it.
> I get the right return result if I called feature.attribute().
> Which platform are you on?
> - Nathan
> On Fri, May 31, 2013 at 12:30 PM, Etienne Tourigny <
> etourigny.dev at gmail.com> wrote:
>> On Thu, May 30, 2013 at 3:12 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>>> Hey all,
>>> I have decided to manage the SIP API update process so that we can have
>>> it done by 2.0. This is an important update as leaving it for later will
>>> break every plugin yet again at later date which just leaves a really bad
>>> taste for people to deal with. A few plugin authors have already expressed
>>> that they would not be impressed having to do another major update again in
>>> the future. And I agree.
>>> So having said that this is the current plan:
>>> - I have created a branch with the SIP API v2 update
>>> - Update all the core plugins in the sipapi-udate[0] branch over the
>>> next couple of days
>>> - Merge into master
>>> I couldn't update all the core plugins myself BUT it would be a lot
>>> easier if I could call on the plugin authors to run though their own code
>>> and do the quick update. The risk of me doing it is that I might break
>>> something and not know it. You know your code best so the help would be
>>> greatly appreciated.
>>> I updated most of the console code and Salvatore has already cleaned the
>>> rest up for me so that is one thing out of the way.
>>> And here comes the kicker: I would like to do this as quickly as we can
>>> so to reduce the gap between master and the branch. The sooner we merge it
>>> to master the sooner we can open it to wider testing, but I don't expect to
>>> run into any major issues when we do.
>>> If you are not aware of what benefits the SIP API update will bring here
>>> is a quick example:
>>> Before:
>>> >>> str(yourlineedit.text().toString())
>>> 'Hello World'
>>> >>> feature["column"].toInt()[0]
>>> 100
>>> After
>>> >>> yourlineedit.text()
>>> 'Hello World'
>>> >>> feature["column"]
>>> 1000
>> I am trying to update a plugin (tileindex) using your branch and I get
>> the following an error
>> fileName = feature[self.attrStr]
>> TypeError: PyQt4.QtCore.QVariant represents a mapped type and cannot be
>> instantiated
>> It seems that feature[], as well as feature.attribute() return a QVariant
>> (defined in qgsfeature.sip), which is incompatible with SIP API v2.
>> How can this be fixed in the plugin or qgis?
>>> It will make life for us and plugin authors a hell of a lot easier.
>>> I have put together a quick guide[1] with some examples. It is open
>>> edit so feel free to add any notes you have. It might be good to turn it
>>> into a plugin translate guide for future plugin authors moving to 2.0.
>>> Regards,
>>> Nathan
>>> [0] https://github.com/qgis/Quantum-GIS/tree/sipapi-update
>>> [1]
>>> https://docs.google.com/document/d/1S85DMEC71AOzTkF1_EpnF0dhVb2On2EVq4E5s1EXoNM/edit?usp=sharing
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130531/79b4446a/attachment.html>
