[Qgis-developer] how to know if QPainter comes from a print job ?
A Huarte
ahuarte47 at yahoo.es
Mon Nov 4 07:48:46 PST 2013
Hi Marco, in "QgsMapRenderer::render" method there is....
//calculate scale factor
//use the specified dpi and not those from the paint device
//because sometimes QPainter units are in a local coord sys (e.g. in case of QGraphicsScene)
double sceneDpi = mScaleCalculator->dpi();
double scaleFactor = 1.0;
if ( mOutputUnits == QgsMapRenderer::Millimeters )
if ( forceWidthScale )
scaleFactor = *forceWidthScale; <------------------------ !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
else
scaleFactor = sceneDpi / 25.4;
if ( mRenderContext.scaleFactor() != scaleFactor )
mRenderContext.setScaleFactor( scaleFactor );
mySameAsLastFlag = false;
I have debugged the code and I have verified.
>________________________________
> De: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>Para: qgis-developer at lists.osgeo.org
>Enviado: Lunes 4 de noviembre de 2013 16:40
>Asunto: Re: [Qgis-developer] how to know if QPainter comes from a print job ?
>>The ScaleFactor is distinct of 1 when the composition engine must paint the map to one specific map scale.
>I think you are mixing up QgsRenderContext::scaleFactor() and
QgsRenderContext::rendererScale().
>Regards,
>Marco
>On 04.11.2013 16:29, A Huarte wrote:
>Hi, Marco, finally I added a flag in 'QgsRenderContext' class indicating that it works in a 'print composition' task.
>>At any rate, thank you very much!
>>>Enviado: Lunes 4 de noviembre de 2013 11:37
>>>Hi
>>>You cannot get that information from the painter
itself (a print composition can be printed into
QImage, pdf, QPrinter, etc...). The safest guess
is probably to look at the QgsRenderContext. If
the parameter 'scaleFactor' is very close to 1.0,
it is most likely the rendering comes from a print
composition.
>>>Regards,
>>>Marco
>>>On 04.11.2013 11:28, A Huarte wrote:
>>>Hi!
>>>>Within of qgis_core I need know if a QgsRenderContext comes from a print job (from composer) in order to disable one functionality.
>>>>I get that information from QPainter, QPaintDevice, QPaintEngine::Type ?
>>>>Thank your very much!
>>>>_______________________________________________
Qgis-developer mailing list Qgis-developer at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland marco.hugentobler at sourcepole.ch http://www.sourcepole.ch Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131104/81913c52/attachment-0001.html>
