[Qgis-developer] cpp-plugin for QGIS 2.0
Andreas Neumann
a.neumann at carto.net
Wed Nov 6 08:45:36 PST 2013
Hi Susann,
As long as there is no API break, your C++ code should work across
versions.
There was an API break shortly between 1.9 and 2.0.
If you target QGIS 2.0 or higher you do not have to deal with QGIS <
2.0.
You can get the sourcecode directly from github at
https://github.com/qgis/QGIS/
See http://www.qgis.org/de/site/getinvolved/index.html for additional
information how to get started.
Compilation has to be done for each platform and major version
separately, as you have to link to the QGIS core libraries. If your
plugin is just for inhouse you just need to target the versions and
platforms you deal with. If it is for general usage and of general
interests and good quality, it would be better to include your code in
trunk with pull requests, so that packagers can bundle it with the
installers.
Good luck,
Andreas
Am 2013-11-06 13:03, schrieb SSchmidt at gfi-gis.de:
> Hello,
> now i try my luck here hoping not being ignored :-)
> I want to write a plugin for QGIS 2.0 Dufour in C++. Do I have to take
> the sources/API from Version 1.8 (Lisboa)? It is right, that the
> actual API only can be used for the actual Releases(Weekly Master)? In
> this case I have to download the actual sources and recompile it
> everytime I want to deploy it?
> Thanks for any suggestions.
> Freundliche Grüße aus Leipzig
> Susann Schmidt
> Softwareentwicklung
> GFI - Gesellschaft für Informationstechnologie mbH
> Philipp-Rosenthal-Straße 9
> D-04103 Leipzig
> Geschäftsführer: Andreas Richter
> Amtsgericht Leipzig HRB 12054
> USt.-IdNr.: DE179049354 Steuer-Nr.: 231/109/06412
> ESRI Solution Partner und ER Mapper Reseller
> Tel. 0341 961 3310 Fax 0341 961 3311 Mail info at gfi-gis.de
> Web www.gfi-gis.de und www.themenbrowser.de
> Qgis-developer mailing list
