[Qgis-developer] WG: Re: WG: Re: WG: Re: cpp-plugin for QGIS 2.0
Nathan Woodrow
madmanwoo at gmail.com
Fri Nov 8 03:11:26 PST 2013
Compared to C++, Python is pretty easy to pick up. There are some really
good Python videos and after you watch a few of them (or even just one) I
would say you would feel comfortable in it. Because the PyQt and Qt C++
APIs are almost the same in terms of porting the code it almost comes right
over; plus or minus a few little tweaks.
I would even say that you would reduce your 3000 line count because Python
is a lot less verbose then C++ and allows for some pretty handy styles that
reduce the needed code.
I use PyCharm as my Python IDE which I have so far found to be the best.
It supports PyQt API auto completion.
- Nathan
On Fri, Nov 8, 2013 at 8:11 PM, <SSchmidt at gfi-gis.de> wrote:
> Hi Paolo,
> yes, our company has to come to a strategic decision in the next time. And
> I'm not sure what to suggest. I don't know python but i think i need much
> time to port ca. 3000 lines existing code, otherwise in future it should
> grow up much more. Besides I'm spoiled of the IDE of VS, i need to look
> what pythondeveloper use for it. And do pythondeveloper not depend on sth,
> like PyQt? QGIS and Qt are programmed in C++, so there wait perhaps no bad
> surprises?... difficult
> Freundliche Grüße aus Leipzig
> Susann Schmidt
> Softwareentwicklung
> GFI - Gesellschaft für Informationstechnologie mbH
> Philipp-Rosenthal-Straße 9
> D-04103 Leipzig
> Geschäftsführer: Andreas Richter
> Amtsgericht Leipzig HRB 12054
> USt.-IdNr.: DE179049354 Steuer-Nr.: 231/109/06412
> ESRI Solution Partner und ER Mapper Reseller
> Tel. 0341 961 3310 Fax 0341 961 3311 Mail info at gfi-gis.de
> Web www.gfi-gis.de und www.themenbrowser.de
> ----- Forwarded by Susann Schmidt/gfi on 08.11.2013 10:40 -----
> *Paolo Cavallini <cavallini at faunalia.it <cavallini at faunalia.it>>*
> Sent by: qgis-developer-bounces at lists.osgeo.org
> 07.11.2013 14:28
> To
> qgis-developer at lists.osgeo.org
> cc
> Subject
> Re: [Qgis-developer] WG: Re: WG: Re: cpp-plugin for QGIS 2.0
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 07/11/2013 10:30, SSchmidt at gfi-gis.de ha scritto:
> > Thank you Andreas,
> > sounds like there is hope for me :-)
> IMHO you need very strong arguments not to do this job as a Python
> plugin. All the external C++ plugins I have seen have died out sooner
> or later for the problems in keeping API and ABI compatibility.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.15 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlJ7lG4ACgkQ/NedwLUzIr4UiwCeOVYAuooE2kFbZFm+h7JubqAH
> HaoAnRjWsVkZ4nYegS9UN6v3JWF2Q6nD
> =5cFj
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131108/9410148f/attachment-0001.html>
