[Qgis-developer] Vector Layer translateFeature() and Qdebug
Pietro Panzeri
pietro.panzeri at treuropa.com
Wed Nov 13 08:45:46 PST 2013
Bump
On Thu, Nov 7, 2013 at 2:07 PM, Pietro Panzeri
<pietro.panzeri at treuropa.com>wrote:
> Hi everyone,
> I'm using QGIS 2.0.1-Dufour from the repository ubuntugis-unstable.
> I have a plugin that is used to translate a vector layer with a shift
> "delta_x" and "delta_y".
> To do this I use the function translateFeature() as you can see from the
> code below:
> vlayer = iface.activeLayer()
> feature = QgsFeature()
> for feature in vlayer.getFeatures():
> vlayer.translateFeature(feature.id(), delta_x, delta_y)
> For every translated feature, the following message is displayed on the
> screen:
> undo index changed 1
> undo index changed 2
> undo index changed 3
> and the plugin execution seems very slow compared to same run under
> version QGIS 1.6.0-Copiapò.
> Looking at the source code it seems that the message is sent through
> Qdebug().
> This means that the QGIS was compiled with debug system activated?
> How do I get a non-debug version?
> Thanks
> Pietro Panzeri
Pietro Panzeri
Software Development Manager
Tele-Rilevamento Europa - T.R.E. srl
Ripa di Porta Ticinese, 79
20143 Milano – Italia
Tel.: +39.02.4343.121 - Fax: +39.02.4343.1230
pietro.panzeri at treuropa.com - www.treuropa.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131113/27759cd6/attachment.html>
