[Qgis-developer] create plyugin: how to compile .ui and .qrc file in windows?
Andreas Neumann
a.neumann at carto.net
Thu Nov 14 00:17:51 PST 2013
Hi Stefano,
The necessary files are already on your computer. They are in
%OSGEO4WRoot%\bin - pyuic4.exe, pyrcc4.exe and designer.exe for creating
forms.
If you use the OSGeo4W shell they should already be in the path. If you
use the regular cmd.exe DOS console you should make sure that
%OSGEO4WRoot%\bin is in your PATH variable.
Hope this helps to get started.
Andreas
Am 14.11.2013 09:08, schrieb Stefano Masera:
> Hi list,
> I want to create my first plugin and I need to compile .ui and .qrc files.
> Unfortunately I'm on windows...
> How can I do?
> Thanks.
> Stefano Masera
> Riservatezza/Confidentiality
> In ottemperanza al D.Lgs. n. 196 del 30/06/03 in materia di protezione
> dei dati personali, le informazioni contenute in questo messaggio sono
> strettamente riservate ed esclusivamente indirizzate al destinatario
> indicato (oppure alla persona responsabile di rimetterlo al
> destinatario). Vogliate tener presente che qualsiasi uso, riproduzione o
> divulgazione di questo messaggio sono vietati. Nel caso in aveste
> ricevuto questo messaggio per errore, vogliate cortesemente avvertire il
> mittente e distruggere il presente messaggio.
> According to italian law D.lgs. 196/2003 concerning privacy, if you are
> not the addressee (or responsible for delivery of the message to such
> person) you are hereby notified that any disclosure, reproduction,
> distribution or other dissemination or use of this communication is
> strictly prohibited. If you have received this message in error, please
> destroy it and notify us by email.
> Qgis-developer mailing list
