[Qgis-developer] [Qgis-user] Cannot create issue (was: raster artefact in composer pdf export)
Richard Duivenvoorde
rdmailings at duif.net
Wed Nov 20 02:07:46 PST 2013
There is a (very concise) text here:
http://www.qgis.org/en/site/forusers/support.html#issue-tracker
which is working for me :-(
After creating an Osgeo account (of which I'm pretty sure Mike already
has (if he is the mike I know :-) ), you can 'just login' at qgis with
your osgeo account (which if you have not 'registred' yet with QGIS will
add you to our 'shadow list of users', giving us the opportunity to add
some user related info/permissions).
So the right track would be
1) create a new osgeo user if not already done:
https://www2.osgeo.org/cgi-bin/ldap_create_user.py
2) use THAT username/password to login at QGIS
via (http://hub.qgis.org/projects/quantum-gis/issues)
https://hub.qgis.org/login
if this is NOT working, please let me know what your (osgeo/qgis) userid
is, I can look it up in our user list.
And if the text is not clear enough, please take some time to make it
clear (an email to me or community list is ok). As
http://www.qgis.org/en/site/forusers/support.html#issue-tracker should
be clear and working.
Regards,
On 20-11-13 09:31, Radim Blazek wrote:
> See below the difficulties to create a new issue. Can somebody comment?
> Radim
> On Tue, Nov 19, 2013 at 3:13 PM, Michael Spencer
> <spencer.mike.r at gmail.com> wrote:
>> Hi I've been trying to report an issue/bug, as requested. The registration
>> process is a very long way from straight forward.
>> I found this page with instructions (no links from qgis home pages, found
>> via a search): http://hub.qgis.org/wiki/quantum-gis/Bugreports. The option
>> for creating an OSGeo account doesn't seem to work (the link works but the
>> process fails, with no explanation why).
>> I've tried to create an account via https://www.osgeo.org/user but the only
>> options are to login or request a new password, not register a new user.
>> I've set up a OSGeo wiki account, but this doesn't work either.
>> Can somebody point me in the right direction as life is too short for this
>> much faff!
>> Ta,
>> Michael
>> On 15 November 2013 10:48, Radim Blazek <radim.blazek at gmail.com> wrote:
>>> I am able to reproduce it with reprojected raster, the dashed lines
>>> appear on original raster extent border. Until we fix that, the only
>>> solution I see is to save reprojected raster and use not reprojected
>>> raster in composition.
>>> Please create the issue anyway.
>>> Radim
>>> On Fri, Nov 15, 2013 at 11:29 AM, Radim Blazek <radim.blazek at gmail.com>
>>> wrote:
>>>> On Thu, Nov 14, 2013 at 6:33 PM, Michael Spencer
>>>>> Hi all,
>>>>> Just updating a figure I originally produced in v1.8 without problem.
>>>>> The
>>>>> aerial photo now generates a dashed line (top and bottom) artefact when
>>>>> I
>>>>> export to pdf.
>>>>> Example here: http://ubuntuone.com/5OmDksQ5O8ppjAX4172ctl
>>>> Please create a new issue and attach a small raster + project with
>>>> comosition reproducing the problem.
>>>> The raster is reprojected?
>>>> The raster is using resampling?
>>>> Radim
>>>>> Any ideas how to fix it?
>>>>> Ta,
>>>>> Michael
>>>>> ps copyright to appear in figure caption ;)
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
