[Qgis-developer] Cannot use data-defined fill color with ellipse marker
Raymond Nijssen
r.nijssen at terglobo.nl
Fri Nov 22 10:39:54 PST 2013
Hi Anita,
The bug I mentioned yesterday is not there anymore in my version. So I
tried to change the colour as well and it also worked. I used a
shapefile with a text field (80 char) and entered values like "#f952ea".
I'll attach is as zip so you can try it too.
Regards,
Raymond
On 21-11-13 10:50, Raymond Nijssen wrote:
> Hi Anita,
> It sounds similar to this issue:
> http://hub.qgis.org/issues/6476
> Maybe data-defined anything won't work on ellipse markers??
> Regards,
> Raymond
> On 20-11-13 18:24, Anita Graser wrote:
>> Hi,
>> Is it a known issue that data-defined fill color does not work with
>> ellipse marker? Whatever color I set there, the result is always
>> black. I didn't find a ticket. Please let me know and I'll open one.
>> Best wishes,
>> Anita
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131122/3fad0019/attachment.bin>
