[Qgis-developer] Disable Syntax Highlighting in DB Manager
Lee Hachadoorian
Lee.Hachadoorian+L at gmail.com
Sun Nov 24 13:24:55 PST 2013
I find the DB Manager SQL window to be unusable, and have confirmed that
it is because of syntax highlighting by disabling this feature in my
installation. There is an issue already in the tracker
https://hub.qgis.org/issues/6995 entitled "db manager's SQL window
freezes with long query (due to syntax coloring?)". Giuseppe suggests:
> Pasting or editing such a query makes highlighting process slow here,
but it doesn't freeze (it could depend on resources available on my
notebook). I could check the query length, but using a 124190 chars
query long is something not usual anyway...
This is correct in that QGIS does not completely stop responding, but
the latency is so high as to make the dialog unusable for anything other
than pasting in an already tested query. Try, for example, typing
`SELECT 1;` into the window, and see how long it takes you. I'm running
QGIS on a Linux Mint 13 laptop with an i7 processor and 8GB RAM, so I
don't think this has anything to do with system resources.
At the moment, I have altered my local version by commenting out lines
34 and 56 of
/usr/share/qgis/python/plugins/db_manager/dlg_sql_window.py. I would
like to suggest that until some time can be invested in making the
syntax highlighting functionality usable (if there is even interest in
doing so for a feature that is just eye candy), that this change be
tested and incorporated in the official version.
Respectfully and with thanks to those who have created and contributed
to the DB Manager plugin,
--Lee
Lee Hachadoorian
Assistant Professor in Geography, Dartmouth College
http://freecity.commons.gc.cuny.edu
