[Qgis-developer] Please approve GarminCustomMap-plugin version 0.100
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Nov 27 05:54:21 PST 2013
Hi again
And Thanks for approving and the hint with the version number.
I was not aware that the loogics change from 0.99 to 0.100.
I shall keep that in mind for the future...
I thought I make it 1.0 (and non experimental) when people out there confirm the plugin works properly on their (probably different systems)...
Cheers
Stefan
-----Original Message-----
From: Richard Duivenvoorde [mailto:rdmailings at duif.net]
Sent: 26. november 2013 22:58
To: Blumentrath, Stefan; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Please approve GarminCustomMap-plugin version 0.100
On 26-11-13 22:16, Blumentrath, Stefan wrote:
> Hi
> It would be great if someone with approval rights could approve the latest version (0.100) of the GarminCustomMap plugin.
> The earlier version did not geo-reference the jpgs properly in the kml/kmz, in other words: output from version 0.99 will be useless...
Hi Stefan,
just did. BUT first could not find it, while it is sorted on version number in the list.
it is because you went from 0.99 to 0.100 == 0.1 So in normal versioning scheme you DOWNgraded your plugin.
So also for the pluginmanager I think your latest version is 0.99
Please version this version as either 0.991 or 0.99.1 or so if you really want to stay away from the magic one :-)
Regards,
