[Qgis-developer] PR1007 bump minimum to 4.7: objections?
Werner Macho
werner.macho at gmail.com
Thu Nov 28 04:36:26 PST 2013
Hi!
>From what I can see (and I agree there with Juergen) only bumping the
version does not make much sense without deleting the
ifdef QT_VERSION ( < = 4.6) in the cpp source code.
Because after bumping the version these lines would not make much
sense anymore ..
I don't know if this can be done somehow in an automatically way.
(and unfortunately I am not a cpp dev - but if anyone explains how to
do it I'll try it)
from everything else ..
+1 for 4.7
regards
Werner
On Thu, Nov 28, 2013 at 11:26 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Regarding last emails from Jürgen and Nyall, is this is a sufficient reason
> to bump to 4.7?
> I don't what is worth my opinion, but +1 for me.
> I believe we should reach a decision soon???
> Cheers,
> Denis
> On 27. 11. 13 11:51, Nyall Dawson wrote:
>> Ok - to add some context to this discussion -- I originally requested
>> that we bump the dependency to 4.6 to get access to
>> QGraphicsItem::rotation() and QGraphicsItem::setRotation(). I need
>> these to fix composer item rotation. It's a bit of a code cleanup, but
>> mostly a feature win in that using those methods I can add rotation to
>> all types of composer items. It's 98% of the way there in these
>> commits:
>> https://github.com/nyalldawson/QGIS/commit/bd92774ea7ea5ed50a4fad9c83f45540125d61e0
>> https://github.com/nyalldawson/QGIS/commit/f05dceb4bd63ca786aa36c0a60a8302567854889
>> Pull request 1007 is basically a prerequisite to finishing this work.
>> If there's no chance of getting the minimum to 4.6 then I'll have to
>> abandon this branch. That's why I'm hoping to get 1007 pulled before
>> spending too much more time on a feature which currently is impossible
>> to merge to master.
>> Early in this thread there was overwhelming support for setting the
>> minimum to 4.8 - that's why request 1006 was opened. 1006 can probably
>> be closed now since 4.8 looks unlikely.
>> Nyall
>> On 27 November 2013 21:43, Sandro Santilli <strk at keybit.net> wrote:
>>> May I ask why this discussion is happening here rather than
>>> on the pull request page ? I'd feel pretty lonely if I was
>>> the contributor of it... :(
>>> --strk;
>>> On Wed, Nov 27, 2013 at 11:26:05AM +0100, Jürgen E. Fischer wrote:
>>>> Hi Richard,
>>>> On Wed, 27. Nov 2013 at 10:25:36 +0100, Richard Duivenvoorde wrote:
>>>>>> I don't see a point in this. The pull request will just break the
>>>>>> lucid
>>>>>> builds without adding anything new (or cleaning out any old code that
>>>>>> requires Qt <4.7).
>>>>> Ok. Clear. Then we should close the two pull requests with the message:
>>>>> we
>>>>> want to provide lucid builds untill .... so before that time we will
>>>>> not
>>>>> upgrade Qt...
>>>> Apparently not so clear. Lucid is not the point. It that it's just
>>>> breaking
>>>> something w/o achieving anything else. And that's essentially the only
>>>> thing
>>>> it does.
>>>> QGIS currently works with earlier versions. That (tiny) change could be
>>>> part
>>>> of a larger PR that removes all the old ifdefed code, that will become
>>>> useless,
>>>> once QGIS refuses to be compiled on Qt <4.7 anyway. Or when something
>>>> else is
>>>> added that requires Qt 4.7 (and which needs some effort to to maintain
>>>> for Qt
>>>> <4.7).
>>>> Jürgen
>>>> Jürgen E. Fischer norBIT GmbH Tel.
>>>> +49-4931-918175-31
>>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>>> +49-4931-918175-50
>>>> Software Engineer D-26506 Norden
>>>> http://www.norbit.de
>>>> QGIS PSC member (RM) IRC: jef on
>>>> FreeNode
>>>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
>>>> mbH
>>>> Rheinstrasse 13, 26506 Norden
>>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> () ASCII ribbon campaign - against html e-mail
>>> /\ http://www.asciiribbon.org - against proprietary attachments
