[Qgis-developer] Shortcut changes in QGIS; call for opinions
G. Allegri
giohappy at gmail.com
Thu Nov 28 08:41:17 PST 2013
We could also ask for confirmation the first time and then let the user
flag a "Stop asking for confirmation", or something like that...
giovanni
2013/11/28 A Huarte <ahuarte47 at yahoo.es>
> Hi Andreas, thanks for your comments.
> I think that the edition (delete features) is much more agile without many
> and repetitive messages boxex. In principle UNDO tool works fine.
> There is a pull request with these changes:
> https://github.com/qgis/QGIS/pull/1010
> Best regards
> *De:* Andreas Neumann <a.neumann at carto.net>
> *Para:* qgis-developer at lists.osgeo.org
> *Enviado:* Jueves 28 de noviembre de 2013 16:33
> *Asunto:* Re: [Qgis-developer] Shortcut changes in QGIS; call for opinions
> Hi,
> I think the confirmation messages are mainly from a time where there was
> no undo possibility available. Assuming that the undo works properly I
> am ok that the confirmation message is suppressed.
> Alternatively we could ask for confirmation if there is more than one
> feature deleted.
> Regarding backspace and delete: ArcMap has an easy situation as it only
> supports Windows where there is always a del-key. We have to support
> multiple platforms. Some keyboards (e.g. Macintosh) do not provide a del
> key - on those keyboards the del-key has to be emulated with
> fn-backspace which is not very efficient and can't be triggered with one
> hand.
> +1 for the additional confirmation when removing one or more layers -
> because there is no undo for that! If there were an undo I would not mind.
> Thank you for bringing up this issues - wonder what the other users
> think - esp. the OSX users.
> Andreas
> Am 28.11.2013 16:11, schrieb A Huarte:
> > Hi, I would know objections in order to change some shortcut keys in
> QGIS desktop.
> > + Delete selected features in map canvas -> DEL key without ask for
> confirmation.
> > Now QGIS ask for confirmation first.
> > Other GIS app desktops, Arcmap, gvSIG.... use DEL key.
> > + Delete selected features in attribute table -> DEL key without ask for
> confirmation.
> > Now QGIS uses Ctrl+D shortcut and ask for confirmation first.
> > + Remove selected node of a feature -> 'backspace' key without ask for
> confirmation.
> > Now QGIS uses DEL key, and similarly 'backspace' already deletes a
> node when drawing a feature.
> > + Remove layer from legend -> Ctrl+D with ask for confirmation.
> > Now QGIS does not ask for confirmation.
> > Our purpose is to standardize these keys and avoid unnecessary and
> continuous confirmation messages in an edit session (You can easily undo
> the removal using the UNDO option menu or Ctrl+Z shortcut).
> > You can see the current discussion in:
> > http://hub.qgis.org/issues/9094
> > Thank you very much!
> > Regards
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131128/19150890/attachment-0001.html>
