[Qgis-developer] [QGIS-Server] Segfault malloc on master
rldhont
rldhont at gmail.com
Fri Nov 29 00:20:40 PST 2013
Hi Marco,
This is an unstable but constant bug.
If I QGIS-Server accessing 2 layers, I have the bug. If I accessing 1
layer, I don't have the bug.
It is unstable because it's not always the same bug. Sometimes it's a
'corrupted double-linked list' like when I close QGIS Desktop, the other
times is a malloc.
I would like to debug QGIS-Server with valgrind but I'm not able to find
the line which malloc.
Herre it's my make config :
sudo ccmake -DCMAKE_INSTALL_PREFIX=/home/***/***/***/build
-DCMAKE_BUILD_TYPE=debug -DENABLE_TESTS=True -DWITH_MAPSERVER=True ..
How do you do it ?
René-Luc
Le 29/11/2013 07:54, Marco Hugentobler a écrit :
> Hi René-Luc
> I don't have a segfault with GetCapabilities here. Maybe it happens
> not with all projects?
> Regards,
> Marco
> On 28.11.2013 15:59, rldhont wrote:
>> Hi Marco,
>> I found time to test QGIS-Server master on gdb.
>> I'm testing GetCapabilities, and QGIS-Server segfaults after sending
>> the document.
>> </WMS_Capabilities>
>> [Thread 0x7fffc6b49700 (LWP 1477) exited]
>> [Thread 0x7fffc73d7700 (LWP 1475) exited]
>> [Thread 0x7fffc7bd8700 (LWP 1474) exited]
>> Program received signal SIGSEGV, Segmentation fault.
>> 0x00007ffff4029cdb in malloc_consolidate (
>> av=av at entry=0x7ffff436c740 <main_arena>) at malloc.c:4094
>> 4094 malloc.c: Aucun fichier ou dossier de ce type.
>> If the segfault arriving before the client receiving all the
>> document, the connexion is closed and the document is incomplet.
>> The GetCapabilities request is not the only one to generate a segfault.
>> Do you have an idea ?
>> Regards,
>> René-Luc D'Hont
