[Qgis-developer] ScriptRunner - wrong error message
Benoît Laurent
blaurent at heurisis.eu
Tue Oct 1 01:37:51 PDT 2013
Hello,
I receive a wrong error message from ScripRunner when I try to reload a
script containing syntax errors. For instance:
#!/usr/bin/env Python
# encoding: utf-8
from qgis.core import (QGis)
def run_script(iface):
if (syntax problem)
"There was an error reloading H:/Temp/stupid_code.py. Perhaps you moved
or deleted it?"
The last sentence is a bit misleading.
Benoît
