[Qgis-developer] Compilation core.sip syntax error and ImportError: dynamic module does not define init function
Radim Blazek
radim.blazek at gmail.com
Tue Oct 1 07:22:45 PDT 2013
On Tue, Oct 1, 2013 at 1:07 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Wed, Jun 12, 2013 at 11:09 AM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Nathan,
>> On Wed, 12. Jun 2013 at 18:03:57 +1000, Nathan Woodrow wrote:
>>> Which platform are you on and what version of SIP do you have? Your
>>> version of might not support something in the header that I added.
>> Also affects lucid - see also 0f3f440cdf0f194c5c1558b936b9058924a324c8
> If I revert 61e101dd4 and 597c4028 it compiles, but QGIS gives on start
> ProcessingToolbox.py", line 57, in __init__
> useCategories = settings.value(self.USE_CATEGORIES, type = bool)
> TypeError: QSettings.value(QString, QVariant defaultValue=QVariant()):
> 'type' is not a valid keyword argument
> so it seems that keyword_arguments="Optional" in Module definition is
> now necessary but it is not supported by SIP 4.10.2. The fix by Jef
> 0f3f440cd fixes compilation, but did somebody try if it also works?
> For me it does not.
> In any case, the fix is only applied if compiled as Debian package,
> would it be possible to do it conditional in .sip files according to
> SIP version?
keyword_arguments Module argument was introduced in SIP 4.12
http://www.riverbankcomputing.co.uk/hg/sip/rev/4a79f5996bd7
Current requirement for QGIS in INSTALL is SIP >= 4.8
Is it really necessary to have keyword_arguments? If yes, we have to
increase the required SIP version in INSTALL. The SIP version should
also be checked by CMakeLists.txt but I don't see any test.
It would mean that Python support will not work on Debian 6.0 Squeeze, bad IMO.
Radim
> Radim
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden http://www.norbit.de
>> committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
