[Qgis-developer] qgis master compile error on ubuntu 10.04
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Oct 4 00:43:01 PDT 2013
Hi Stefan,
Looking at the INSTALL file, minimum requirements for SIP is 4.12,
while Ubuntu 10.04 still ships SIP 4.10 I think.
So unfortunately, yes, you are probably out of luck.
Regards,
Matthias
On Don 03 Okt 2013 17:05:30 CEST, Marco Bernasocchi wrote:
> which is the error after a make clean?
> Marco Bernasocchi (mobile)
> http://opengis.ch
> On 3 Oct 2013 16:58, "Ziegler Stefan" <Stefan.Ziegler at bd.so.ch
> <mailto:Stefan.Ziegler at bd.so.ch>> wrote:
> Yes. Some sip version problem?____
> __ __
> I can run make four times with errors and the fifth time it
> compiles without errors. But then I get an error on qgis startup
> that pyqgis will be disabled.____
> __ __
> Regards____
> Stefan ____
> __ __
> *Von:*Marco Bernasocchi [mailto:marco at bernawebdesign.ch
> <mailto:marco at bernawebdesign.ch>]
> *Gesendet:* Donnerstag, 3. Oktober 2013 16:54
> *An:* Ziegler Stefan
> *Cc:* qgis-developer
> *Betreff:* Re: [Qgis-developer] qgis master compile error on
> ubuntu 10.04____
> __ __
> thats all you get as error? ciao____
> http://opengis.ch____
> On 3 Oct 2013 15:48, "Ziegler Stefan" <Stefan.Ziegler at bd.so.ch
> <mailto:Stefan.Ziegler at bd.so.ch>> wrote:____
> Hi
> Now I get some errors in the gui part:
> [ 55%] Generating gui/sipguipart0.cpp, gui/sipguipart1.cpp,
> gui/sipguipart2.cpp, gui/sipguipart3.cpp
> sip: /home/stefan/Develop/src/qgis_master/python/gui/gui.sip:1:
> syntax error
> make[2]: *** [python/gui/sipguipart0.cpp] Error 1
> make[1]: *** [python/CMakeFiles/python_module_qgis_gui.dir/all]
> Error 2
> make[1]: *** Waiting for unfinished jobs....
> [ 56%] Built target gpsimporterplugin
> [ 56%] Built target topolplugin
> [ 56%] Built target heatmapplugin
> [ 57%] Built target spitplugin
> [ 60%] Built target georefplugin
> Regards
> Stefan
> > -----Ursprüngliche Nachricht-----
> > Von: qgis-developer-bounces at lists.osgeo.org
> <mailto:qgis-developer-bounces at lists.osgeo.org>
> [mailto:qgis-developer- <mailto:qgis-developer->
> > bounces at lists.osgeo.org <mailto:bounces at lists.osgeo.org>] Im
> Auftrag von Ziegler Stefan
> > Gesendet: Donnerstag, 3. Oktober 2013 10:14
> > An: qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> > Betreff: [Qgis-developer] qgis master compile error on ubuntu 10.04
> > Hi
> > I get an compile error on Ubuntu 10.04:
> > [ 31%] Generating analysis/network/sipnetworkanalysispart0.cpp,
> > analysis/network/sipnetworkanalysispart1.cpp,
> > analysis/network/sipnetworkanalysispart2.cpp,
> > analysis/network/sipnetworkanalysispart3.cpp
> > [ 31%] sip:
> /home/stefan/Develop/src/qgis_master/python/core/core.sip:1: syntax
> > error
> > sip:
> /home/stefan/Develop/src/qgis_master/python/analysis/network/networkanalysis.sip:1
> > : syntax error
> > make[2]: *** [python/core/sipcorepart0.cpp] Error 1
> > make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all]
> Error 2
> > make[2]: ***
> [python/analysis/network/sipnetworkanalysispart0.cpp] Error 1
> > make[1]: ***
> [python/CMakeFiles/python_module_qgis_networkanalysis.dir/all] Error 2
> > Should the master still be compilable on 10.04?
> > Regards
> > Stefan
> > Freundliche Grüsse
> > Stefan Ziegler
> > Leiter amtliche Vermessung
> > Amt für Geoinformation
> > Amtliche Vermessung
> > Rötistrasse 4
> > 4500 Solothurn
> > Telefon +41 32 627 75 96 <tel:%2B41%2032%20627%2075%2096>
> > Telefax +41 32 627 75 98 <tel:%2B41%2032%20627%2075%2098>
> > stefan.ziegler at bd.so.ch <mailto:stefan.ziegler at bd.so.ch>
> > http://www.so.ch
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/qgis-developer____
